Seas Prestige FU10RB H1600-08 4" Full Range - new at Madisound
Old 19th September 2013, 02:15 PM   #31
vacuphile is offline vacuphile  Netherlands
vacuphile's Avatar
Originally Posted by juanito View Post
It's okay, but I'm not sure if the drivers need burning ..
A driver only needs burning if it's really, really bad
But from now on I will be discrete about it.
Old 19th September 2013, 02:23 PM   #32
sayrum is offline sayrum  Germany
Afaiu drivers change when used (suspension loosens up for example)
I find it questionable to burn/break in drivers for hundreds of hours while listening to them. The ear - brain - mind gets acoustomed to the soundsignature that way, so afterwards there is no telling if the driver realy changed for the better or if the listener got used to it. -> Mesurements help
Old 19th September 2013, 02:34 PM   #33
diyAudio Member RIP
Originally Posted by xrk971 View Post
What circuitry do you suggest - a crossover ( cap) to let the top handle say 1 khz and
up and let the bottom run full range? I would rather not use full blown crossovers.
A series inductor to the lower driver calculated for BSC.
The bottom driver does bass only, top is full range.
rgds, sreten.
Old 24th September 2013, 04:40 PM   #34
juanito is offline juanito  Europe
juanito's Avatar
Do you think this kind of tweeter Vifa OT19NC00-04 3/4" Fabric Dome Tweeter 4 Ohm 264-1122 will be okay to cover the higher frequencies with these Seas fullrange?
I like the mids a lows given that its a portable soundsystem. Those vifas are rated up to 30khz, so I would just add these with a simple filter like supertweeters, am I right? I know I did this with Fostex as they recommend with their fullranges: for example the FX120 and the FT17H with a single Cap used as filter or crossover. Does it apply the same or similar with these vifas?
It would be great because the size of these vifas is really suitable for the boxes.
Other solution is to try the Scan Speak 10F in fullrage.
Old 24th September 2013, 05:51 PM   #35
vacuphile's Avatar
Juanito, there is a Vifa dome tweeter in the same housing that I am using a lot because it is really good. I use them 4th order LR and you can really play them loud.
Seas Prestige FU10RB H1600-08 4" Full Range - new at MadisoundHide this!Advertise here!
S11 OB - Revisiting Desktop OB design using Seas 8" and Tang Band Full-Range gainphile Multi-Way 28 27th May 2016 08:13 AM
SEAS Prestige CA22RNX (H1288) 8" Coated Paper Cone Woofer limono Swap Meet 2 20th April 2012 09:24 PM
Seas full range in 1,5-way saschagabor Full Range 6 27th January 2011 04:43 AM
SEAS X1-08 Exotic F8 8" full range driver jackfish Full Range 6 16th March 2009 09:48 PM
Full range driver at Madisound on sale EmergencyDpt Full Range 2 20th November 2008 09:39 PM
Copyright ©1999-2017 diyAudio
