Seas Prestige FU10RB H1600-08 4" Full Range - new at Madisound - Page 3 - diyAudio
Old 18th September 2013, 07:26 PM   #21
juanito is offline juanito  Europe
juanito's Avatar
Well, I finally got a pair of FU10RB 4 ohm version at ebay.
I put them in sealed compartments of 1,5 litres aprox. I also managed to put in a third compartment a TA2021 board, a linear power supply of 12 V, an alps volume pot and a switchcraft 3,5 mm jack. I think they call it a boombox. I used an old central DIY speaker box I had layng arround. It's something I had in mind to do: smallish portable hifi system.
Got other things for full proper hifi.
It's okay, but I'm not sure if the drivers need burning or may be the amp need to be changed or ad some crossover parts...
May be the source, as I've been using an iphone and spotify: not the best source!
But the intention is to get the best mini portable hifi system. I cannot compare to my 2 way diy loudspeakers, its just a diferent thing.
I feel that at mid high volumes it can distort; olso it depends on the tracks I'm playing, for example rock or music with lots of instruments and voices it can get a bit muddy.
I've got to keep on trying: which is fun!
One of the changes I was considering is to use the connexelectronic TA2022 with SMPS and volume pot module. Looks very convinient for the power rating and it's small and compact.
Nice to fit in a smaller place.
Any suggestions? Any experiences with these fullranges?
Bye
Old 18th September 2013, 07:57 PM   #22
diyAudio Member RIP
FWIW it doesn't look much like a genuine FR to me, more a wide range
HT bass/mid with good Xmax best used with a small top end tweeter.
This is IMO a high value FR The Madisound Speaker Store
rgds, sreten.
Old 18th September 2013, 08:20 PM   #23
sayrum is offline sayrum  Germany
Originally Posted by sreten View Post
This is IMO a high value FR :
The Madisound Speaker Store.
I second that notion!
Clean, fine high frequency and no cone break up hurting your ears
Used in a flat wall mounted enclosure (like a thick picture frame) no baffle step correction needed.
Old 18th September 2013, 08:50 PM   #24
xrk971 is offline xrk971  United States
xrk971's Avatar
You can add me to the list of Vifa TC9FD fan club. I have built all types of speakers with these. Great sound. Great value.
Old 18th September 2013, 10:12 PM   #25
diyAudio Member RIP
Two in a small box arranged as a 1.5 way away from walls
(as they have full BSC) will image somewhat better I imagine.
Not much not to like about a 4 ohm 1.5 way over a single
driver 8 ohm version, the extra 6dB sensitivity and SPL.
rgds, sreten.
(1.5 way is often called 0.5 way, but I think that is wrong.)
Old 18th September 2013, 10:56 PM   #26
xrk971's Avatar
I am currently running dual Vifa's in a mini Karlsonator and they sound fantastic. The extra 6 dB sensitivity really makes them come alive and effortless. They still image very nicely.
Old 18th September 2013, 11:01 PM   #27
diyAudio Member RIP
But the intrinsic BSC and dispersion of a 1.5 way is better than 2 drivers 1 way.
I can't imagine you can't make things better manipulating one (lower) driver.
rgds, sreten.
Old 18th September 2013, 11:30 PM   #28
xrk971's Avatar
What circuitry do you suggest - a crossover ( cap) to let the top handle say 1 khz and up and let the bottom run full range? I would rather not use full blown crossovers.
Old 19th September 2013, 11:09 AM   #29
tvrgeek is offline tvrgeek  United States
This one is on my short list as a midrange. Maybe, just maybe it is a driver that can behave between 500 and 5K in a 3 way. Not sure on the breakup modes. If we can get a REAL midrange and push the crossovers out of the critical hearing range, then all the "continuity" so sought after by the full range camp may be obtainable and still have a listenable result.
Old 19th September 2013, 11:23 AM   #30
This one is also a fabulous midrange.
I use it with the Monacor DT-28N in a MTM configuration (+ 2 SPH-225 C)
S11 OB - Revisiting Desktop OB design using Seas 8" and Tang Band Full-Range gainphile Multi-Way 28 27th May 2016 08:13 AM
SEAS Prestige CA22RNX (H1288) 8" Coated Paper Cone Woofer limono Swap Meet 2 20th April 2012 09:24 PM
Seas full range in 1,5-way saschagabor Full Range 6 27th January 2011 04:43 AM
SEAS X1-08 Exotic F8 8" full range driver jackfish Full Range 6 16th March 2009 09:48 PM
Full range driver at Madisound on sale EmergencyDpt Full Range 2 20th November 2008 09:39 PM
Copyright 1999-2017 diyAudio
