Coral Holey, what to do? - diyAudio
Old 6th May 2012, 07:48 PM   #1
Default Coral Holey, what to do?
I purchased two Sony TC-500 tape recorders at a very low cost. The plan is to use the amplifier parts to build two new amps. Both recorders amps work fine as-is and sound pretty sweet with the coral holeys (opened the backs of the enclosures and removed stuffing). With the current amp, a 6aq5 SE the system is surprisingly loud. I would like to make new enclosures but one of the pairs has stiffer surrounds (150hz fs). The other pair has soft surrounds and are giving me around 90hz fs.
So two questions;
For the 150hz pair, can someone recommend an inexpensive small woofer that could be used only to assist the bottom end? The plan is to give away the systems to my family. I could potentially bi amp the speakers as the tc500 output transformer has a 600 ohm tap that could be used to feed something like a small class d amp.
Second, is the 90hz fs low enough to put the other pair in a small horn loaded enclosure? Or maybe a small BR enclosure?
Alfredo
Old 8th May 2012, 03:12 PM   #2
bump
Old 10th May 2012, 04:44 PM   #3
pjanda1 is offline pjanda1  United States
pjanda1's Avatar
For the stiff pair, the easiest solution might be a pair of inexpensive subs (pre-made from PE) ala the Bottlehead S.E.X.y speakers. For the better pair, do you have enough room for BIBs?
Paul
Wild Burro Audio Labs - DIY Full Range Speakers
Old 10th May 2012, 07:23 PM   #4
Thanks Paul,
The plan is to give these away, so the smaller the better. The cheap powered woofer for the stiff one is not a bad idea. Possibly attaching a front baffle and running the speakers in OB.
I have been eyeing the frugel horn MKIII, maybe that works. I have a complete woodshop in my garage so I can build pretty much anything.
Alfredo
Old 10th May 2012, 07:50 PM   #5
chrisb is offline chrisb  Canada
Originally Posted by avincenty View Post
Thanks Paul,
Alfredo
FH3 is as good a candidate as any for a BLH approach for the lower Fs pair (need I reiterate the disclaimer of "see signature below"? ), but you would likely want to contemplate powered woofer(s) - and maybe build with the top removable to allow for easy access to "tune" damping fill levels by ear - that way if the Corals don't quite make the grade, at least there's a wide range of other drivers known to work well in the enclosure.
on hiatus
Old 10th May 2012, 08:05 PM   #6
frugal-phile(tm)
planet10's Avatar
Many pairs of these i've had have had SSS (stiff surround syndrome), which makes them useful only as mid-tweeters. I would put them in a small sealed or aperiodic enclosure with a woofer each. XO will need to be <200 Hz.
The Fs of the other pair puts them very close to where they were new and should be gems. FH3 is a good candidate for these, Aiko another. Solo 103 or Fonken103 for small enclosures.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 10th May 2012, 08:11 PM   #7
Thanks chris, dave
How about the MKII? I have a new pair of 126n that I could use if the corals dont pan out. Are the corals worth a try over the 126's?
Alfredo
Old 10th May 2012, 08:29 PM   #8
frugal-phile(tm)
planet10's Avatar
MkII what?
dave
Old 10th May 2012, 08:33 PM   #9
Originally Posted by planet10 View Post
MkII what?
dave
Frugel horn mk 2?
Alfredo
Old 10th May 2012, 08:42 PM   #10
frugal-phile(tm)
planet10's Avatar
FH2 was still-born. It never existed.
dave
WTB: Coral Beta 10, Coral 12TX-50 mik190 Swap Meet 0 21st November 2011 10:24 AM
Enclosure for Coral holey baskets? mfaughn Full Range 1 12th September 2011 02:19 AM
Holey-Basket Coral FE103A (alnico) variants pjanda1 Swap Meet 4 1st February 2011 04:59 AM
Holey Basket Coral TL's on Ebay pjanda1 Full Range 0 29th December 2009 02:53 PM
Holey-Basket Coral FE103A variants pjanda1 Swap Meet 3 20th October 2009 04:02 PM
Copyright 1999-2017 diyAudio
