Alpair 7.3 Bookshelf Bass Reflex? - Page 4 - diyAudio
Old 3rd May 2012, 04:00 AM   #31
Bigun is offline Bigun  Canada
Bigun's Avatar
Dave is the guru on this, but I'll take my shot at what he's saying.
The first derivative is a measure of the slope of the curve, of the FR curve. If the slope is up then the first derivative is larger than zero, if the slope is down the first derivative is negative, if there is no slope and its dead flat then the first derivative is zero.
You also get a flat spot on the FR curve at the top of a bump or at the bottom of a hollow. And either side of the top of a bump or bottom of a hollow, the slope of the FR curve changes from going up (or down) to going down (or up). So over the course of a bump or hollow in the curve the first derivative will change sign (from + to -, or from - to +) and in doing so it 'crosses zero'.
So no first derivative rule means no bumps or hollows in the FR plot. The 'wrong' choice of box size and/or port dimensions will product bumps/hollws in the FR plot.
To play with this I use this excellent BR calculator which shows the FR plot: Loudspeaker enclosure calculating with Thiele Small parameter
I used Dave's approach to tuning up my Martello enclosure and to my ears it sounds good.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 3rd May 2012, 04:10 AM   #32
frugal-phile(tm)
planet10's Avatar
Originally Posted by StevenZ View Post
The chart was done on the work computer. I'll see if I can blow it up tomorrow and change the color to something easier to identify.
I replicated it in my modeler. The read arrows point to where the 1st derivative crosses zero (it also does up above 200 Hz, but that one doesn't really concern us). You will also see how the blue line (group delay) zooms off the top of the chart. In the 2nd chart is the 14/50 again, Jeff's 7L/55Hz, and what i'd do 9L/60 Hz) as well as 7 & 14 L sealed.
When looking at bass extention pay attention to F10, Toole determined that F3 doesn't tell you much (which was pretty much understood already).
You can't tune the 7L much higher with a round vent as it will become underdamped. My tuning assumes a high-R vent which knocks the bump down (increased damping -- the highR vent also makes for higher tolerance to dynamic T/S changes as they move along their curves).
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 3rd May 2012, 04:10 AM   #33
StevenZ is offline StevenZ  United States
Okay. I think I'm following you Bigun. Where I was getting lost is that at no point after 100hz does the FR go above 0+. Though you see two bumps they're below zero as stated in a previous post. I'll see if I can smooth out the response to have zero bumps and a gradual roll off. So what is the general consensus here? Are we aiming for something about 8liter tuned to 55hz? Someone shoot me a target enclosure size and tuning and I can play around from there. I'd like to start slingin' some saw dust by Friday.
Thanks,
Steven
Edit: Posted at the same time as Dave's post which answers the questions I asked in this post.
Old 3rd May 2012, 04:14 AM   #34
Awesome, thanks Dave! So by high-R vent, you mean using a high resistive vent, something like the 1" you advised of in a previous post, correct? Looks like I'll be knocking down some cabinets pretty soon.
-Steven
Old 3rd May 2012, 04:32 AM   #35
frugal-phile(tm)
planet10's Avatar
To have a high R vent it needs to have a high aspect ratio and as long as you can get away with.
dave
Old 3rd May 2012, 04:44 PM   #36
So, here we are today. I'll go with your recommendation of a 9L box tuned to 60hz with a 1" port. When I plug all this into my box calculator it tells me that the port should be 1" long. Could you confirm this?
Thanks,
Steven
Old 3rd May 2012, 07:31 PM   #37
frugal-phile(tm)
planet10's Avatar
I get 29mm. Note that i'd use this tuning oonly with a high ratio slot vent (in which case you can use the CGR as a reference. With a cylindrical port i would tune a bit lower -- say 40mm x 1" vent.
dave
Old 3rd May 2012, 09:36 PM   #38
vinylkid58's Avatar
FWIW, here's a screen shot of a 9 litre box with 1.5" (38mm) long vent.
heff
Old 10th May 2012, 10:39 AM   #39
My cabinets based on the reflex port design listed on Mark Audio's website.
So nearly finished...
Old 2nd June 2012, 10:07 PM   #40
Default bookshelf BR A7.2
Is the br-cabinet for the A 7.3 also useful for the A 7.2? If not: does anyone know a custom bookshelf br-design for this speaker?
Thanks,
Peter.
Bass Reflex Bookshelf Cabinets for Mark Audio Alpair 7 Full Range Driver Musik007 Twin Audio 56 11th April 2013 04:53 AM
Alpair 6 Bass Reflex Bookshelf EUVL Full Range 65 1st November 2012 01:17 AM
New BR Bookshelf Cabinet for Alpair 12 Musik007 Twin Audio 21 6th April 2011 05:32 PM
Copyright 1999-2017 diyAudio
