Alpair 7.3 Bookshelf Bass Reflex? - Page 2 - diyAudio
Old 2nd May 2012, 08:47 PM   #11
tuxedocivic's Avatar
Originally Posted by chrisb View Post
I think that's definitely something not to try with any of the Alpairs
Why not?
I wouldn't do that in my living room, but nearfield the EL70 barely exceeds 1mm of travel.
Old 2nd May 2012, 08:53 PM   #12
frugal-phile(tm)
planet10's Avatar
When i was simming these my 1st derivative rule was broken for any box over about 9 litre (1.2 ft^3 ~ 14 litre)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 2nd May 2012, 08:56 PM   #13
StevenZ is offline StevenZ  United States
And what is your 1st derivative rule? I'm not sure I follow where you were going with that statement. Are you confirming that the .5ft@50hz box sim would work, or would not work?
-Steven
Old 2nd May 2012, 09:17 PM   #14
frugal-phile(tm)
planet10's Avatar
The 1st derivative of the FR curve does not cross 0 more than once.
Sticking to this rule has allowed us to keep tight tuneful bass response.
dave
Old 2nd May 2012, 09:27 PM   #15
Oh, I see. Thanks for the clarification. Using the box porting and size I posted earlier it doesn't cross more than once, though it comes close. It's lowest point is a 0.52db drop at 70hz and finishes off with a 0.3db drop at 50hz.
Old 2nd May 2012, 09:46 PM   #16
frugal-phile(tm)
planet10's Avatar
For that to be true the 1st derivative has to cross zero at least 2x
dave
Old 2nd May 2012, 09:50 PM   #17
I'll take your word for it as you obviously have a vast knowledge of box designing and I'm sure a more accurate way of measuring frequency response of enclosures. From what I'm seeing in WinISD is that it never crosses 0 even with those two figures I gave you. What could be the difference of results between what I'm modeling and what you're modeling? Is WinISD inadequate for designing enclosures using FR drivers?
-Steven
Old 2nd May 2012, 09:57 PM   #18
I've attached a couple photos for you to take a look at. Let me know if you see any discrepancies in the parameters that I'm not seeing that may be causing it to not show the frequency response rising above zero.
Thanks,
Steven
Old 2nd May 2012, 10:35 PM   #19
Does winisd allow for modelling of stuff in a vented box? I know unibox does and I find (in the model and audibly) that adding stuffing to a response like you have there can mellow out the tuning peak.
Old 2nd May 2012, 10:42 PM   #20
chrisb is offline chrisb  Canada
Originally Posted by tuxedocivic View Post
Why not?
I'd be concerned about over stressing the much more delicate metal cone of the Alpair, but we could always ask Mark about that.
on hiatus
Bass Reflex Bookshelf Cabinets for Mark Audio Alpair 7 Full Range Driver Musik007 Twin Audio 56 11th April 2013 03:53 AM
Alpair 6 Bass Reflex Bookshelf EUVL Full Range 65 1st November 2012 12:17 AM
New BR Bookshelf Cabinet for Alpair 12 Musik007 Twin Audio 21 6th April 2011 04:32 PM
Copyright 1999-2017 diyAudio
