Old 13th May 2012, 08:41 AM   #11
Scottmoose's Avatar
Glad you can do that.
Since your amplifier has 8ohm & 16 ohm taps, then it would be logical to series wire, rather than parallel wire, the 125s. Note that a single 125 is extremely unlikely to work in this cabinet; twin units have a better chance, but I make no guarantees, since it was not designed for this driver.
I don't know re the tweeter; the only way to find out is to try it. Note that rear-firing may be problematic since these cabinets were intended to be used quite close to a front wall. Again, there's only one way to find out if you like the results though.
Old 29th May 2012, 07:40 AM   #12
Default Re: Let's also look at other options!
Hi Scott,
Just wanted to update you on our progress with Olivia Chang's but as I have been reading up on full range speakers I cannot help but wonder about the Mark Audio series drivers that could also work in Olivia Chang's... What is the difference between the CHP's CHR's and Fostex FF125wk? besides the evident SPL inefficiency of MA's!? What would happen if I used the EL70's instead of the FF125wk? I almost certainly would notice the MA;s having to turn up my volume on my amplifier to drive them louder, but seems to me the bass extension would be better than the Fostex's would you agree? what about sound clarity and depth?Qts of EL70's is .55 Fostex are .42 and seems the lower the Qts the more cabinet size and horn loading is needed....anyway your comments are definitely appreciated! Lydia
Old 31st May 2012, 12:19 AM   #13
Lydia,
I'm not Scott and may be out of line, but you asked for a recommendation for current drivers for this cab and you got one. Scott is well aware of the Mark Audio drivers and I believe he would have recommended one if he thought it was the best match for this cab.
You have insisted on building a cab based on an unavailable driver and have been warned that you are in undiscovered territory. So, either build w/ the FF125WK and see how it works, or stop now and build an existing design. No one can give further advice. Your first mistake was cutting wood before you checked on driver availability. IMO you are continuing the mistake by building boxes that may not work for the FF125WK. The sole bright side is that there are designs for the FF125WK so if the Olivia's don't work out you haven't wasted driver money.
I was so much older then, I'm younger than that now.
Old 31st May 2012, 01:53 AM   #14
zman01 is offline zman01  Bangladesh
Lydia,
Jumping in before Scott and +1 to what fastbike1 has already said.
If you want to go for EL70 then you should check out the Coniston or the Coniston^2 design. for Mark Audio CHR-70 it will Lotus or Lotus^2. If you use the forum search function or use google, you will find some user impressions on both Lotus and Coniston designs.
For both builds it is likely that you will be able to salvage some of the wood you have cut for the Olivia Chang.
Old 31st May 2012, 05:13 PM   #15
Scottmoose's Avatar
Let's not. I'm sorry, but I simply don't have the time at the moment to assess a wide range of drivers in an obsolete enclosure that is unlikely to be built again. My PhD takes priority I'm afraid. The 125s should do OK, of the existing units (or at least stand the best chance of working).
Ref: ScottMoose BVR "OLIVIA CHANG" pianolydia Full Range 1 28th April 2012 09:04 AM
Lowther in Chang variant--question for Scottmoose and Dave ludcam Full Range 4 10th February 2012 07:38 PM
Olivia Chang Spassgeneral Full Range 43 5th July 2009 07:43 PM
Half Chang or Suzy Chang with Subwoofer? tripathdude Full Range 2 15th December 2008 04:47 PM
FAO: Scottmoose whitecrook Multi-Way 0 16th November 2008 01:47 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
