Ref: ScottMoose BVR "OLIVIA CHANG" - diyAudio
Old 28th April 2012, 04:23 AM   #1
Default Ref: ScottMoose BVR "OLIVIA CHANG"
Hi Scott,
I am building a pair of Olivia Changs BVR's
and is using the Fostex FF125wk the best driver to use?
about dampening, should I use 1/16" cork and line the walls
all sides except baffle? I envisioned using 1-1/2" Polyfill/fiberglass combo and line one side, back, and top only! I want that resonant bass only coming out of those horn mouths. I love clear mids/lush, and sparkly Hf. Will I be able to get that out of the OLIVIA's? would if I only line the back what would happen? need your advice thanks,
Lydia
Old 28th April 2012, 10:04 AM   #2
Scottmoose's Avatar
Oh blimey, that box is still archived? Most of those obsolete cabinets should have been taken down months ago (Dave simply doesn't have enough hours in the day to continue with the FH site's much-needed revamp). Off hand I don't know whether the 125 will work acceptably or not, but possibly; I'll try to check if I have a few minutes later. Ideally, you really need something that was designed for the 125.
Cork shouldn't be needed; 1 1/2in fiberglass is likely going to be overkill; I'd probably look at 1in, or 1/2in.
Olivia Chang Spassgeneral Full Range 43 5th July 2009 08:43 PM
BVR as designed by Scottmoose and others jamikl Full Range 3 13th August 2007 09:47 AM
Copyright 1999-2017 diyAudio
