Old 24th April 2012, 11:41 PM   #1
tiefbassuebertr's Avatar
Default Alnico Instrumental Speakers+Super Tweeter as an Option for very expensive Full-Range
Fullrange speakers are mostly very expensive as long as alnico is in use (above 10.000 US-$ in case of Monster-Alnico from Feastrex) Here some examples:
Supravox
215 EXC SUPRAVOX
165 LB SUPRAVOX
SEAS
http://www.seas.no/images/stories/ex..._datasheet.pdf
Lowther
Lowther Loudspeakers -
PHY
PHY-HP (Haut parleurs)® - H 21 LB 15 SAG
PHY-HP H 30 LB 15 SAG (PHY)
PHY-HP Open Baffle
Voxativ
Voxativ Loudspeakers
Expensive Full Range.
http://www.eltim.eu/data/mediablocks...-X-Test-LR.pdf
VOXATIV Full range drive units
Decware
Decware FRX Full Range Driver
Decware's Audiophile Product Page
New FRX OB driver from Decware
HiWell/HW-Speaker "08HF46D"
08HF46D:8",35 W RMS,70 W program,1" coil-hiwell
products_Hiwell speaker
L.Cao alnico/Onecaudio
L.Cao full range speakers
Feastrex Monster Alnico
Products
Photo-Gallery-NatureFlux
http://www.lotusgroupusa.com/RetailOnLine_09.pdf
BD-Design - Feastrex
Feastrex and Fostex Compared at Lone Star Audio Fest
What about the consideration to use guitar legend speakers with Alnico magnet system together with a super-tweeter so as the appopriate additional equalization?
Are there already experiences?
Here some examples of the good known versions from such instrumental transducer models:
Celestion G12 Blue (30 cm, 329,-- used e.g. in Vox AC-30 TBX)
Alnico - Celestion Blue - Celestion - Guitar, Bass & Pro Audio Speakers
Celestion Blue Bulldogs 12"
Celestion Blue Bulldog Alnico 12'' 15W 8 Ohm Made In England - Celestion
Vintage Amps Bulletin Board • View topic - Celestion blue cone codes w/PICS
http://swartamps.com/images/Celestion_Blue_full_900.jpg
http://www.bazaar-world.com/uploads/...42241951-2.jpg
The VOX Showroom - The Vox AC-30TB and AC30TBX Amplifiers
Celestion G10 Gold (221,--, e.g. Fender)
Alnico - Celestion G10 Gold - Celestion - Guitar, Bass & Pro Audio Speakers
Celestion Alnico Gold Bulldog 10" 8 Ohm
Celestion Gold Alnico Bulldog 10'' 40W 8 Ohm Made In England - Celestion
http://farm5.staticflickr.com/4139/5...91157459_z.jpg
http://mmusicmag.com/m/wp-content/up...-June-2011.jpg
http://www.teamaudio.fr/media/catalo..._gold-15_1.jpg
Celestion speakers in a Deluxe Reverb - Telecaster Guitar Forum
Celestion G12 Gold (30cm, 295,--)
Alnico - Celestion Gold - Celestion - Guitar, Bass & Pro Audio Speakers
Celestion Alnico Gold Bulldog 12 8 Ohm
Celestion Gold Alnico Bulldog 12" 50W 8 Ohm - Celestion
Celestion gold image by Twinhit on Photobucket
Fane AXA 12 (30 cm, 249 Euro)
Fane International Ltd Loud Speakers
http://www.fane-acoustics.com/downlo...ta%20Sheet.pdf
Fane AXA-12 12" 100W 16 Ohm - Axiom
FANE AXA-12 Speaker Cabinet
Fane AXA 10 (25 cm 245 Euro)
Fane AXA-10 10" 100W 16 Ohm - Axiom
Eminence LEGEND 1028K (99,--)
http://www.eminence.com/pdf/Legend_1028K.pdf
Eminence Legend 1028K
Jensen P10Q (96,--)
P10Q | Jensen Loudspeakers
Jensen P10q 10 8ohm
Jensen P10Q 10'' 40W 8 Ohm - ALNICO SERIES
VDS HP Jensen P10Q
Jensen P10R (79,--)
P10R | Jensen Loudspeakers
http://www.aceguitarparts.com.au/jensenp10r.jpg
http://www.vintageguitaramplifiers.n...4003799191.jpg
http://sp.j-guitar.com/uploads/1630/...c5-6630-48.jpg
Jensen P10R Alnico Vintage 8OHM
Jensen P10R 10'' 25W 8 Ohm - ALNICO SERIES
http://images.thomann.de/pics/bdb/11...883327_800.jpg
Jensen P8R (79,--)
P8R | Jensen Loudspeakers
Jensen P8R 4 Ohm
Jensen P8R 8" 25W 8 Ohm - ALNICO SERIES
http://www.eifl.co.jp/index/speaker/...jensen_p8r.jpg
Jensen P12R (89,--)
P12R | Jensen Loudspeakers
Jensen P12R 12" 25W 8 Ohm - ALNICO SERIES
Jensen P12R Alnico Vintage 8Ohm
http://www.blackswampaudio.com/Images/Inv/1269.2.jpg
http://bild9.qimage.de/jensen-p12r-a...d-46653269.jpg
http://imgc.classistatic.com/cps/bln...0891c1_23.jpeg
Frequency response Jensen:
Jensen® Vintage Speakers
Basics
http://www.tt-cabs.com/tt_tech/doc/T..._Leitfaden.pdf
Weber Speakers
https://taweber.powweb.com/weber/
Old 24th April 2012, 11:59 PM   #2
more pics - Eminence/Fane
Old 25th April 2012, 12:01 AM   #3
more pics Jensen P8R from various generations
Old 25th April 2012, 12:07 AM   #4
more pics Jensen P10Q and P10R
Old 25th April 2012, 12:12 AM   #5
last pics from Jensen's P12R
Old 25th April 2012, 02:23 AM   #6
Hi, And your point / subject is ? rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 25th April 2012, 03:30 AM   #7
d to the g's Avatar
THAT is a lot of links. Measuring most any guitar speaker will show why the majority are no good for hifi. Peaky response and no bass are almost prerequisites.
Old 25th April 2012, 02:15 PM   #8
Quite true.
Guitar speakers are voiced to have peaks in the top end (which ends about 5K). They have huge magnets and stiff surrounds so most have an Fs near 100Hz, despite the heavy cones. And, the accordion surrounds make them non-linear, with a Qts of close to 1. What more could you ask for?
I actually listen to a lot of music played through guitar speakers, as that's how I break them in. The bass in a TL (and they will go low in a TL) is very natural for bass guitar, not so inspiring for cello or even acoustic guitar. Kick drums however, sound dead on. Male vocals are... forward is an understatement. But it's the cymbals that will drive you from the room. Did I mention the cone of a guitar speaker is designed to have massive amounts of harmonic distortion?
If you must, try one of these:
http://www.wgs4.com/content/BHHP
Very smooth through the highs (for a guitar speaker), but the weak magnet/heavy cone will want to make a nasty bump in the mid-bass.
Old 25th April 2012, 04:40 PM   #9
zmyrna is offline zmyrna  United Kingdom
The only guitar speaker that found its way into diy audio is Tone Tubby.
Lynn Olson likes the TT 12" alnico.
People have used it with Lowthers or horn tweeters on top.
Some also use the TT 8" fe version as a wide ranger.
The rest is pretty much hopeless.
But the alnico tubbies are not cheap in Europe.
If you are after affordable alnico, look for vintage.
Germany is probably the best place for finding vintage alnicos.
I have got myself some beautiful new old stock Isophons on German ebay. 15-20 euros each.
Old 25th April 2012, 05:15 PM   #10
chrisb is offline chrisb  Canada
well, not all "guitar / musical instrument" speakers have "huge" magnets (relative to cone size) - eg Eminence Beta 12TA 34oz for 12" cone, FS at 60Hz avg sens= 99dB , while say Fostex FE163En weighs in a 38 oz for 6" full range ( Fs 56 and avg sens=93dB) - of course that's apples to oranges and I doubt anyone would use any of the Fostex FR drivers for guitar speakers (for long at least), but the reverse is not necessarily the case.
The Tone Tubby's are great, but certainly not the only guitar speakers that have found their way into DIY audio - see Eminence cited above, and of course there manufactures such as Hawthorne and Hammer Dynamics catering to the DIY crowd with custom OEM drivers from this same company
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
1 New Pioneer PIM-25A vintage alnico full-range speaker tweakk Swap Meet 1 30th December 2011 05:24 PM
old 10" Philips Alnico Full Range alejo Full Range 5 12th November 2011 05:01 AM
Expensive Full Range. milesian Full Range 20 7th February 2011 06:05 PM
FS: Alnico ~4" Full-range Drivers speaker Swap Meet 7 21st March 2009 09:55 PM
DIY Super Cube full range speakers audiophile36 Full Range 14 29th August 2006 11:11 PM
Copyright ©1999-2013 diyAudio
