Snowboard boombox - diyAudio
Old 21st April 2012, 01:31 PM   #1
Default Snowboard boombox
Hi all,
First of all I like to state that I'm a total newbie when it comes to building a speaker. This will be my first. I've got an old snowboard and would like to build some speakers on it powered by batteries. The source will be a MP3-player. I already have two 12W amps.
What is need is a nice speaker design. Because I want to place it on my snowboard the height of the box is very restricted. The max speaker size is about 8x8x2inch.
My priorities are:
- CHEAP
- Heavy on bass
- Loud
- Light
- Really cheap
Greetings,
Pure
Old 21st April 2012, 10:15 PM   #2
kctess5 is offline kctess5  United States
Are you planning on using your snowboard with the thing attached?
Your requirements look a little unrealistic to be honest. See Hoffman's Iron Law. It states that to get efficiency you need either less bass or a bigger box, you can't have a very small very efficient box with a lot of bass.
If your planning on using it on the slopes I might suggest headphones. Of you just want it to be decorative then you need to think about rethinking the size
Old 21st April 2012, 10:53 PM   #3
More accurately your requirements are very unrealistic, not a little.
It simply cannot be done, for any price, nevermind very cheap.
rgds, sreten.
8"x8"x2" might be 7"x7"x1.5" internally, assuming 1/2" ply and
using the board as the back. That is 1.2L. suits a 3" driver, e.g. :
http://www.madisoundspeakerstore.com...m-silver-cone/
Which you should be able to fit by drilling a hole for the magnet.
The best bass your going to get with about 10W on tap.
That is as good as it gets with ~ 10W and that box volume.
Old 21st April 2012, 11:21 PM   #4
All true. As I said, headphones are a much more viable option. Smaller, cheaper, muuuch better bass
Old 22nd April 2012, 12:00 AM   #5
All true but no bling factor ! If the OP wants to give it a go the NS3 is the
best bass driver available for around 1L at a sensible cost and will take
about 10W of power in the bass. It won't be as loud, deep or bassy as
the OP would like / imagines, but its one way of learning limitations.
Its fun I guess, and no harm in saying use this driver if you wan't to do it.
rgds, sreten.
A 5mm xmax, (10mm pk to pk), 3" driver will impress most people a lot.
Old 22nd April 2012, 12:46 AM   #6
Banned
My brother and I used to put speakers in everything when we were kids, great way to learn and foster interest and creativity.
Everything had a stereo, boats, lawn tractors, sheds and even the GT snow-racers. (Snow sled)
Sure it might start to fall apart but you will have fun in the meantime.
Old 22nd April 2012, 02:15 AM   #7
Good point!
I've used the Dayton version of that driver, the nd91 and i can attest to its unusual bass capabilities. That's definitely what i would suggest if you want to do this. A driver with over 2cm of xmech can do wonderous things. It's got good dispersion too...
I wasn't trying to discourage you in my previous messages but just know the limitations and don't be disappointed if the bass doesn't debone nearby chickens.
Old 22nd April 2012, 02:55 PM   #8
Thanks for all the replies. Maybe I need to adjust my wish list a bit. Cheap is still pretty important. It a fun project and headphones are not a option, I wish to share my music.
So what I need a decent sounding speaker with the dimension I gave. I could make it a little higher but not too much. It still has to be ridable. It doesn't have to be heavy on the bass side. Just not too low. I need some bass.
Old 25th May 2012, 04:40 PM   #9
Just curious. Where are the 10W amp and the power supply or batteries going to go?
Old 25th May 2012, 06:10 PM   #10
nazaroo is offline nazaroo  Canada
Banned
Batman Utility Belt?
This PC not only looks like a movie prop, it's a fully-functional computer. Featuring an Intel Core 2 Duo E4500 (2.2-GHz) processor, 2GB RAM, GeForce 8400 GS graphics, 500GB HDD, and an ASUS P5E-VM motherboard. Video after the break. Click here for first picture in gallery.
There are wires interconnecting the various parts - you can see the power supply's yellow tentacles snaking all throughout the setup - as well as green liquid cooling tubes making sure everything is cool
[via Gizmodo - Modshop]
LINK HERE
Bluetooth Boombox SHAD0WF0X Digital Source 5 6th August 2015 12:57 AM
DIY boombox Scarbwill Class D 1 8th September 2011 04:31 PM
Boombox no.2! :D Zenolijo Class D 24 7th April 2011 08:00 AM
Cal's little boombox Cal Weldon Multi-Way 33 3rd December 2010 08:36 PM
DIY Boombox happyb Multi-Way 4 27th March 2008 09:30 AM
Copyright 1999-2017 diyAudio
