How does changing coil DCR affect sound? - diyAudio
Old 4th April 2012, 12:07 AM   #1
cyto is offline cyto  United States
cyto's Avatar
Default How does changing coil DCR affect sound?
I was wondering how going with a larger gauge coil, and thus a lower dcr, actually changes the sound.
I see opinions saying that the dcr should stay the same but can anyone say how the sound is affected?
Old 4th April 2012, 12:10 AM   #2
SY's Avatar
It depends on where and how the coil is used. In general, you'll get frequency response changes if you change the DCR, but what the changes are and how big they are will vary from case to case.
Unless you're replacing iron core coils that are run hard enough to saturate, there's little to be gained from "upgrading" inductors.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
How do fuses affect the sound quality? audiogeekess Multi-Way 2 17th March 2012 03:39 PM
EV SP12C with too-low output and too-high coil DCR... jon_010101 Multi-Way 2 21st June 2009 10:31 PM
Does Voice Coil Affect Magnetic circuit? kelticwizard Multi-Way 28 13th October 2007 02:12 AM
transformer specs such as DCR and etc: how does it affect voltage on the secondary? jarthel Parts 10 1st September 2006 03:18 PM
does the resistor's ppm affect the sound? mekanoplastik Parts 9 4th June 2003 05:21 AM
Copyright 1999-2017 diyAudio
