The Fountek Five for FR88ex
Old 8th April 2012, 12:41 AM   #21
chrisb is offline chrisb
Originally Posted by planet10 View Post
It is a 3". Whether a sub is needed depends on how much bass you expect, and how loud. It should have an edge on things like Tabaq & Cybord Needle.
dave
"sub"
and I'd consider these candidate for stereo woofers XO'd much higher than the normal range of most sub plate/etc amps - IOW at least in the 200 -250 HZ range
Got word from Scott, the Voigt sims to F3 ~65, F10 ~55.
dave
F10?
kinda burnt out - taking a break
Old 8th April 2012, 12:49 AM   #22
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
typos fixed, thanx Chris
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 10th April 2012, 05:03 PM   #23
inrank is offline inrank  United Kingdom
inrank's Avatar
Dave, would the folded Voigt work with the Fountek FE87?
Could the driver be mounted on the side face, at the same height as before? Monilith style?
And whats the size of the folded voigt?
Old 10th April 2012, 06:14 PM   #24
would the FE87 "work"? - yes it would make some sound, but likely not as well as the driver for which it was designed - and that bigazz shielding magnet assembly will certainly make for a very tight fit - requiring substantial chamfer to rear side of cutout
internal clearance to back panel would be very shallow, and I'd be surprised if it didn't demonstrate "congestion"
page 7 of plan set in first post (drawn for 15mm material - adjust as necessary for different thickness)
internal dimensions - 100mm W x 318mm D x 864mm H, - fold divider centered at 151mm from top
Old 10th April 2012, 09:11 PM   #25
inrank's Avatar
Righto Cheers
Old 10th April 2012, 09:30 PM   #26
frugal-phile(tm)
planet10's Avatar
Maybe work with the FE87. QW resonators are fairly tolerent and all the similar 3" Fountek have similar T/S.
Mounting on the side should be fine, you might want to adjust abit to keep Zd. Chris' concerns about early reflections -- an sB might come in handy in this respect.
dave
Old 11th April 2012, 07:25 AM   #27
inrank's Avatar
Thanks, whats 'sB'?
Old 11th April 2012, 07:38 AM   #28
frugal-phile(tm)
planet10's Avatar
sB = supraBaffle
Like this one:
dave
Old 11th April 2012, 07:49 AM   #29
inrank's Avatar
Ah right, and it would need to be rear mounted on that supra baffle, one thing I found is that the terminals are larger than the cut out required, and there is not really any overlap from the front of the frame. I wish the FE87 came with the nicer round frame of the FE85.
Fountek FE87 1 by hoopsontoast, on Flickr
Fountek FE87 2 by hoopsontoast, on Flickr
Old 11th April 2012, 08:24 AM   #30
frugal-phile(tm)
planet10's Avatar
Yes, those look like they would be best mounted from the rear, in which case a sub baffle of some sort would be needed.
Keep in mind that the sB doesn't need to be a circular donit like ours. A retangle with bevels would do to.
dave
The Fountek Five for FR88exHide this!Advertise here!
Martello enclosure for FR88EX Bigun Full Range 218 30th January 2017 01:59 PM
Fountek FR88EX 3" build malibujeff Full Range 22 16th March 2016 10:25 PM
FR88EX Fountek Vendor's Bazaar 10 3rd April 2012 10:21 PM
FR88Ex based micro-Onken ? Bigun Full Range 34 3rd April 2012 10:21 PM
WTB: Aurasound NT1, Fountek FR88EX, NHT surplus woofers. Spasticteapot Swap Meet 0 11th July 2009 01:00 AM
