#51 |
Nice. I'm also a little surprised it work so well in that small of a room. Mine's about 1/3 smaller than that so don't know.
#52 | |
But again my opinion about units dimension is that it has to be relatively in Size(at that XO) if you want it to sound authenticaly the best it can... I apologize(for posting in your thread it won't happen again), and no hard feelings Cheers
some of my Designs www.dynablaster.deviantart.com/gallery |
#53 | |
Is it all it takes for somebody to be insulted. I must say that I am quite surprised how little it takes before people around here becomes defensive.
I hope i didnt insult anybody Last edited by DogStar; 13th May 2012 at 08:59 PM. |
#54 |
Location: Checotah, Okrahoma former home of the Okra Fest
I heard these at the Lone Star Audio Festival.
I also heard the MLTL's Bob had on hand. I thought both sounded wonderful. Perfect, no, but then we are talking about a hotel room here. There were a large number of exhibitors in attendance who had ~6.5" w/ Tweeter either in MTM or TMM arrangements that just drove me out of the room with the bass bloom in the lower mid bass. It's difficult to bring a combo that will work well in these rooms. I would rank Bob's efforts as some of the best of show. I was unaware that this thread existed until today, I actually went to the show hoping to hear his MLTL's, and was not dissapointed. The OB's were like icing on the cake. I've met Bob at the show a couple of times now, and enjoyed each one. LSAF is unique in it's blend of high end botique and DIY, it's become a ritual for me to attend, and I've enjoyed every year more than the previous. John |
#55 |
Since page 1 I’ve been thinking of how to replicate the original sound of the bigger baffle, but with narrower one.
I did it too. First, I made an even bigger OB, which was terribly ugly and a waste of plywood too as FR driver choice was poor Then I made a smaller 8x12 in baffle and suspended it in order to have four open edges as I had only the Tolvan Data EDGE (didn’t had the MJK Mathcad sheets then as the sole Idea of Math%$@0# was frightening), which is unaware of boundaries, or floor, so I had to have a dependable simulation - voala the suspended OB was born. Then I put on it a more efficient Fane 6 inch midrange and had the required headroom to fill in the hole. Then the problems began, the system became more sensitive to placement, the bass was not quite the same. Then I read more and then it came to me... The OB is an integral part of the H frame... some self education follows... Then it is either 6db eq@<30hz or the bigger OB, then the placement... Then it struck me, why don’t I have a look at the original design simulations just to see where, how and why the H-frame extends. And finally: Well, small baffles do exist, you just have to make them work for you ![]() You don't follow the same guidelines with small baffles, it's just the opposite, you must flaw them to have the room to shave the excess and be left with the proper performance. Right now, I fired up the edge, just to recall. See what happens if you center the FR@125x125mm relative to the lower left corner on a 250x350mm baffle (centered 4.9in above the lower edge of a 10x13.78in baffle). - you get 200 Hz@-5 or -6db relative to 2 kHz, and a 4 db peak with ~4db/oct slopes - e.g. solvable with LC 1st order notch with lowered Q such as higher dcr inductance, both centered at 1 KHz. Maybe 1st order passive crossover, L-Pad or a single series resistor, RLC notch and a Zobel. Or maybe there is a more elegant way for achieving the same, but I’m not an engineer so this way serves me as a listener. Then maybe a properly aimed LR-4 and it should be beautiful or since you already have the -6 db point, you can add 1st order cornering lower (175hz?) and a greater order cornering at FR driver Fs?Then the H frame, my system is passive and I am completely happy with 13 mh and 150uf, just adjusted the OB to it with some additional crossover work, padding, the padding required impedance equalization and etc., but the musicians were given permission to enter the room ![]() Slightly on another track, the H frame told me that the saying for the non-directional ever protruding never reflected bass were just that sayings. You have to hear them with the original big OB's to know how much of a shield it actually is, not only an aid for the FR. Best regards! P.S. almost forgot welcome to the Goldwood community... And... I originally wanted to protest about the dead under 30 claims, but you heard Organ I purchased the Bach Complete Organ Works, never mind it's at least 1/2 German funeral music, it's deep! And there are some well recorded bass drums across my collection which light the 20 Hz bulb on my EQ and it makes a difference to have the 1858 on the other end of the wire maybe smallest match amongst known speakers are mine 15 in 16.6 Fs Daytons in 200+L EBS doghouses ![]() Beat regards again!
Ikea Omni Bowl Speakers - New Project My Bulgarian Forum: http://penkiller.com/index.php Last edited by T101; 13th May 2012 at 10:58 PM. |
#56 |
When i made my ob's nobody believed that they would reach below 700hz.
I managed to push mine down 350hz before doing the tweaking with a frequency within +/- 3db, before putting in a xover. In Norway we have this constructor who have been pushing boundaries with putting elements in builds they shouldn't been working. I believed he said that there were no fun in trying out things that already had been tested. I believe that there are some x-factors, things not possible to figure out. Building speakers is one of them. When a element is tested and measured, its done in "dead-chambers". No reflections make it not possible to know for sure how it will work out in an OB. I guess doing equations conserning how a speaker would act is safe, but i believe there are many kinds of truths. So saying that Bob is wrong is not right, unless uve tried it yourself.
Tubes, horns & DIY.. |
#57 | |
Martin King's spreadsheets are used by hundreds of DIY'ers. On his web site is an H frame sub, full range driver on top combo that has been built by quite a few people. Jim Griffin's H frame sub with an Alpair full range which he has posted, was voted best in it's class at a major DIY event. The concept does work. As Bob pointed out, there are numerous threads about the F.A.S.T. concept. But to be fair, this is my opinion - that I supported by hearing Bob's design, and several others that use the concept. I also referenced several other successful designs by some of the other respected contributors to our hobby. Any opinion that does the same would and should be welcome on this and any other forum. As I feel that this has become unproductive to Bob and his design, this is my last post regarding it. And no, you did not insult me. |
#58 |
Although it sounds against logic or more correctly against "conventional practice" to match a big heavy woofer with a light 4" or 3" wideranger, the whole concept of a FAST is based on this: a light full range driver with a helper woofer. Many, starting with the founder of this concept , Martin find this configuration to also provide benefits of full range sound with no crossovers in the critical range.
Looking at typical crossover points around 300-400Hz, it is noteworthy that the woofer actually does not have to move very fast even if when reproducing the highest frequency it is asked to play at i.e. ~400Hz. On the other hand the widerange driver is light enough to move fast to reproduce 20 KHz, but at the same time should not have any problem moving as slow as the woofer at ~400Hz. So I fail to understand the concern about matching hugely different driver sizes of different weights. The only area of concern might be the narrow polar response of a large woofer when asked to play at very high frequencies. However if crossing at 300Hz the shortest wavelength produced by a 15" woofer is 1/3rd of the woofer diameter, and only 1/4th for a 12" woofer, that should not cause obtrusive beaming at higher end of the woofer bandwidth. I dont know if my above understanding is wrong or I am missing something here ?! |
#59 |
I just checked out the website, looks pretty cool. I don't think there are many of us 'technical types' on this forum that create that kind of art. Reminds me that there is a diverse range of people on a forum like this and it can be difficult for all of our 'styles' to adjust to the local on-line 'culture'.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#60 | |
First I haven't heard these speakers and know nothing about them. In reading thsi thread, today for the first time I would observe the following, the designer pointed out the faults of the first try at thOB, other posters offered suggestions and where they think problems could be. Bob seemed receiptive to the suggestions while pointing out the constraints he is placing on the design. Bob then found problems and was happy with the results while again acknowledging what the shortcomings of the speaker are. For someone like me to come here and say something can't work and basically can or cannot do without hearing the speaker seems a bit rude and yes insulting. There was nothing that Bob said that called for that sort of abrasivenes. |
| Not Your Daddy's Dipoles | matevana | Multi-Way | 16 | 8th September 2010 02:39 PM |
| M-dipoles | el`Ol | Multi-Way | 1 | 25th February 2010 09:12 AM |
| Dipoles ? | LennyK | Multi-Way | 111 | 21st September 2006 03:12 PM |
| 3-way or 4-way dipoles? | mazeroth | Multi-Way | 0 | 25th January 2006 06:37 AM |
| Spicatto Dipoles | Raka | Multi-Way | 42 | 6th November 2004 07:00 PM |
