BiB help.
BiB help.
Old 1st April 2012, 04:14 PM   #1
gafhenderson is offline gafhenderson  United Kingdom
Default BiB help.
attached is an output for a BiB from the MJK worksheets.
i am assuming this is terrible yes?
what do i do to avoid the massive low-end hump?
the phase goes crazy too, is this going to result in a muddled sound?
basically HELP!
thanks
Old 1st April 2012, 04:26 PM   #2
zman01 is online now zman01  Bangladesh
BiB help.
You can have a look at this monster thread:
http://www.diyaudio.com/forums/full-...handbooks.html
Properly stuffed and placed near corners, the BiB in room sound is very good actually. Lot of satisfied users out there.
Old 1st April 2012, 04:41 PM   #3
changed the listening position to be more accurate and realised i had the wrong reflective surface mode thinger.
does this look ok?
Old 1st April 2012, 04:54 PM   #4
BiB help.
I am no expert, but FR chart looks better.
I am pretty sure GM (Greg Monfort) will have some words of wisdom for you.
Old 16th April 2012, 03:55 PM   #5
bumping with new design sim.
is this worth building? i can go down to the drivers 50hz Fs (not at any reasonable volume tho) without exceeding 1mm of woofer displacement (according to simulation) using 10watts, giving a resulting 100db noise which should *hopefully* be loud enough for the room. anything lower than this and i exceed 1mm displacement unless i keep the volume 5-10db quieter.
Old 16th April 2012, 05:30 PM   #6
Godzilla is offline Godzilla  United States
Godzilla's Avatar
What driver are you using?
Old 16th April 2012, 05:42 PM   #7
that big 12" FANE thing.
http://www.fane-acoustics.com/downlo...00LT_Specs.pdf
i'm still fumbling through various designs trying to find something that gives modest bass @ high enough volume to fill the space, without going over that 1mm displacement that i've read i want to adhere, in order to avoid excessive doppler muddling up the sound.
any help would be greatly appreciated with enclosure types. apereodic was suggested @ around 50ltrs but this seems too hit and miss (for my competence level) and isn't the type of enclosure i want to use when i'm finished learning and playing and get some real drivers. so i'd prefer to try and use a transmission line et al type design.
thanks.
Old 16th April 2012, 06:40 PM   #8
Godzilla's Avatar
You can do OB with this as long as you have bass support. Attached is my effort. Same goes for sealed. Just seal the driver up and add bass support (does not have to be H-frames like i did, can be a powered sub of your choice). I know about the aperiodic 'empken' design. It looks like a winner to me and may not require bass support.
Zilla
Old 16th April 2012, 11:54 PM   #9
GM is offline GM  United States
GM's Avatar
Cab wise, only a huge BLH will have enough acoustic gain to allow high SPL down low at only 1 mm excursion.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 17th April 2012, 12:20 AM   #10
Zilla
i'm not sure i'm a fan of the OB sound. I have subwoofer designed but i was hoping not to need it too much, i could theoretically use the 2x12" subs with an OB but they're fairly crappy car drivers picked up for very cheap, as playthings.
i've got the MJK, U and H baffle frames but i'm not 100% on how to use/sim it for comparison to my other bodged efforts.
BiB help.Hide this!Advertise here!
My BiB davethomp Full Range 18 29th January 2009 11:06 PM
my new BIB (again...) nirvana Full Range 31 24th December 2008 06:13 PM
AJ-Horn & BiB - ar some BiB "parabolic"? freddi Full Range 3 6th April 2007 04:09 PM
This BIB is OK? Jaime Full Range 8 30th September 2006 09:22 AM
Copyright ©1999-2017 diyAudio
