Need a Driver - diyAudio
Old 1st April 2012, 02:27 AM   #1
Default Need a Driver
2" or smaller
It must play from 400-2kHz with very low distortion, similar to Fountek 89.
Any suggestions?
Thanks!
Old 1st April 2012, 06:33 AM   #2
Not sure what your application is, but the HiWave BMR12's are pretty interesting for a compact full-ranger. HiWave BMR12 Compact 2" Full-Range Square Speaker 12W 8 Ohm 297-210
Old 1st April 2012, 06:35 AM   #3
Chicago,
Any idea where I can get charts on it's distortion?
It's very cheap compared to the driver I'm comparing it to, so I'm scared the quality will not be very good.
Old 1st April 2012, 07:15 AM   #4
Here is your datasheet: http://www.hi-wave.com/downloads/dat...BM36S12-4A.pdf
The BMR technology is attracting a lot of interest, as here: Near full range BMR (Balanced Mode Radiator). Why not try them out? At $13 apiece, or something, it's pretty hard to go wrong.
Old 1st April 2012, 07:19 AM   #5
That doesn't tell me about distortion, mate.
Old 1st April 2012, 07:24 AM   #6
Sorry, best I can do. Maybe someone else can help you.
Old 1st April 2012, 02:06 PM   #7
fakeout is offline fakeout  Canada
fakeout's Avatar
Is the Aurasound NS3-193 a candidate? The only other one I can guess quickly is the Tang Band W3-881. I'm merely guessing here though.
Old 1st April 2012, 02:26 PM   #8
zman01 is offline zman01  Bangladesh
OP wants 2"or smaller.The BMR looks interesting. There are some small Tang Band drivers at PE too. But haven't tried out any and no idea on distortion.
Old 1st April 2012, 03:28 PM   #9
tuxedocivic's Avatar
Icor, why care about distortion? I recognize your name from techtalk. They're distortion crazy over there. But most research says we shouldn't be putting much weight on distortion results.
Perhaps if you explained your objective we could be more help. Perhaps a 3" would work. Larger cones inherently have less distortion in the range you're asking about.
Old 1st April 2012, 06:21 PM   #10
A 3" won't work, as I mentioned I've found a good candidate for that size already.
I need a 2" or close to it, for excellent off-axis response in the Hz range I need it to operate at.
Suggestions appreciated.
L-pad attenuator for midrange driver 6 1/4 inch driver rhythmdiy Multi-Way 0 4th November 2007 04:32 PM
Base driver to suit ESS Heil driver gerado Planars & Exotics 6 1st August 2007 08:56 PM
FS: Silver Iris Coaxial 15" driver pair (sans XO and compression driver) theAnonymous1 Swap Meet 0 24th April 2007 01:09 AM
Driver/ driver configuration improve soundstage width andy2 Multi-Way 6 16th June 2005 09:47 PM
mtm versus tm driver recommendations on project with $500 driver and xo part limit gsattler Multi-Way 4 20th May 2002 06:54 PM
Copyright 1999-2017 diyAudio
