Fostex 10F05AV drivers - diyAudio
Old 30th March 2012, 07:32 PM   #1
Default Fostex 10F05AV drivers
I have a pair of Fostex drivers 10F05AV like these. I not found any information about them. Only they are mounted on the Fostex 6301, a small active monitors with good sound.
Does anyone know the specs of these 4 inch?
I would like to mount some small monitor with a TA2020 amp or similar for the laptop.
Any suggestion for the cabinet and filter ?
Old 30th March 2012, 08:32 PM   #2
chrisb is offline chrisb  Canada
looks like might be most closely related to the now discontinued consumer FE107E - in which case something along the lines of 4 liter or so, vented along the lines of
http://homepage.mac.com/tlinespeaker...-0v999-map.pdf
I know this one works well with the FE127E
edit: note that Fostex had a couple of "recommended" enclosures for the FE107E, including a simple BR at 6 liters, tuned to 95Hz, and a very "interesting" mine HT sound bar .
http://www.fostexinternational.com/d.../107e_encl.pdf
... so, not as easy at it sounds, this letting go thing
Fostex Drivers reddal Full Range 10 26th January 2012 02:46 AM
fostex drivers babgrip Full Range 0 1st December 2008 06:13 AM
fostex drivers brian t Full Range 3 15th January 2005 06:08 AM
where can I get fostex drivers alg123 Full Range 4 26th August 2004 12:54 PM
Fostex Drivers Konnan101 Multi-Way 15 9th February 2004 03:15 AM
Copyright 1999-2017 diyAudio
