I am thinking of building a speaker using a Mark Audio Alpair 6P.
The speaker has a built in Baffle Step Correction as shown in the following link: Markaudio Alpair-6P Paper Cone 3.5" Fullrange Gen 2: Madisound Speaker Store To me this would imply that there is some optimal baffle width that should be used. The Mark Audio website has two bass reflex plans though, one with a wide baffle and one with a narrow baffle. I would like to simply build a sealed box though. Can anybody recommend dimensions for a sealed box for this driver that takes proper account of the built in BSC? If I were to try a bass-reflex design, I need help understanding the width required with respect to the built in BSC and why Mark Audio has two plans for bass-reflex with different baffle widths. Thanks. |
#2 |
Whether sealed or bass reflex, it doesn't affect BSC for the most part. Baffle width and height is the biggest factor. And edge treatment will affect the diffraction where the baffle reaches full 2pi. The dip around 1khz in the manufacturer's spec sheet indicates a small baffle would be best. Maybe 7" x 12" or 10". There's a free program called EDGE that can simulate this for you.
| Alpair 6p vs alpair 6m vs alpair 7 | timreeves | Markaudio | 11 | 8th January 2013 03:37 PM |
| TB W5-1611SA, Alpair 6P, CSS EL70s | wushuliu | Swap Meet | 3 | 7th February 2012 05:14 AM |
| Markaudio Alpair 6P in a 2-way-system | LXB | Multi-Way | 11 | 22nd January 2012 01:34 PM |
| Mark Audio Alpair 6P Application Thread | simon dart | Full Range | 5 | 3rd April 2011 02:20 PM |
| Alpair 6P Gen. 2 (paper) introduction | markaudio | Markaudio | 21 | 20th November 2010 02:10 AM |
