Zigmahornet is just a quarter of a wavelenght long and straight. My old Zigmahornet measures 150cm in height and has a Fostex FE103Z. The inner width is 10cm and depth 8cm. These were made in the 80's I believe. The "port" measures 10cm x 4 cm.
To get the quarterlenght you use this formula:
33130/fs*0.25
example for a driver with 70Hz:
33130/70*0,25= 118,3cm
For the start of the pipe you use the same area as the cone and the "mouth" the coneareax3
There are lots of stuff about this on this forum. Use the searchfunction.
33130/fs*0.25
It was the first speaker that I made, mainly to check if I was handyenough and also beause they look rather pleasing. For ease of cosntruction I kept the top flat however.
The speaker was interesting, was convincing for acoustical music, but it also convinced me that 10cm speakers do offer not solid enough bass for me.
2) what are the best to use TB (the economy line, for use in micro HFI or PC)
THANK YOU
Do you have driver model numbers or can you post a pic?
There are some other slim floor standers like the Needle and Tabaq.
MODEL TB ECONOMIC
W2-780SD 13,90EUR
W2-800SJ 13,55EUR
W2-802SE 12,68EUR
W2-803SK 16,32EUR
W2-835SI 16,85EUR
W4-654S 22,05EUR
think that is the best solution zigmahornets for full range economic. to use speakers for pc or micro hifi and maybe for use with t-amp
i wanted to use driver tb why are easy to find
i find the xl file bamed tqwpmetric to build tqwp sistem
grazie
W2-780SD 13,90EUR
W2-800SJ 13,55EUR
W2-802SE 12,68EUR
W2-803SK 16,32EUR
W2-835SI 16,85EUR
W4-654S 22,05EUR
grazie
You can try this driver maybe:
Anmelden - Lautsprecher Selbstbau by blue planet acoustic
A project for this can be:
http://www.diyaudio.com/forums/full-range/88787-tabaq-tl-tang-band-29.html
This is the folded version of the Tabaq making it around 44cm in height; original version is taller and less deep.
- Full Range
- Zigmahornet or TQWT with Tang Band
