#31 | |
Obviously you do need to take your time with it, but it can be done. Here are some pics of the Fonkensteen's I built which I believe are a bit bigger than the Mar-kel. I did these in multiple passes with an 80T blade, previously I cut the bevels on a pair of Fonken-prime's the same way... |
#32 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#33 | |
What method did you use to make the irregular flush mount for the 120? |
#34 |
I know the Mar-Kel70 is a proven design; but i am curious how the width of the front baffle effects the imaging? because of the 45 deg.angle cuts the front is fairly narrow. No doubt wider baffles have been tried. Thank-you!
#35 | |
frugal-phile(tm)
dave
#36 | |
while not specifically restricted to the EL70, we've tried a succession of wide/shallow enclosures over the years (most recently with the EL166/FF85K MTM) , and while they can definitely add what our friends at SH used to call "balls" (due no doubt in part to reduction of baffle step loss) and width of soundstage, the narrower baffles tend to excel at more precise imaging and resolution of depth tall double mouth horns/manifolds such as Spawn family etc function effectively as MTMs due to the LP filtering of driver coupling chamber (in a Back Loaded enclosure of any type, the room is the "compression" chamber ), and can deliver tremendous image scale while retaining what I'd describe as precise location specificity, albeit at the expense of build complexity and required listening distance and interesting compromise I've found quite workable (for my situation at least) are variations on narrow bipoles - most notable something like the MicroTowers
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#37 | |
#38 |
Hey Doggy,
I am listening to the BBC 3 overnight stream and really digging the mMar with my Helder TA2020 amp. So much joy for so little cash. I am going to try and build a new trapezoidal enclosure for the EL70s later in the spring/summer. The EL70 has so much more to give that it's a shame to have them cooped up in the mMar. KM |
#39 | |
As far as the irregular driver cut out goes, I used the technique outlined on an exquisiteaudio.ca page, which unfortunately doesn't appear to be online anymore. Basically it involves making two templates with a router (1/4" straight bit), you run the router around the perimeter of the driver to create the first template. Then run the router around the inside of the first template to create the second. Then use the 1/4" bit and a 3/4" bushing with the second template to cut the actual recesses. A bit of a PITA, but it does work. I do have the web page saved if you are really interested. |
#40 | |
. Thanks goes to Dave and ChrisB for their suport in my info. search. The front bevels are 30 deg., for what reason i ran out of faceplate space for the bevel-maybe i cut some material a little short for trimming. It is a solid box, using the 3/4" maple. Just playing one speaker now as the faceplate glue is drying on the 2nd unit. The EL70 is very musical and articulate.
| Mar-Kel70 in Sweden | Rullknufs | Full Range | 1239 | 30th December 2012 08:52 PM |
| mMar-Kel70 vs Mar-Kel70 | Bigun | Full Range | 17 | 3rd May 2012 08:47 AM |
| Three flavours of Mar-Kel70 (for EL70) | planet10 | Planet 10 hifi | 7 | 17th January 2012 08:15 AM |
| mMar-Kel70 in Chile | AlejandroR | Full Range | 0 | 17th August 2011 01:56 PM |
| Do i need to build main supply (240v) filter?Or build power distribution? | thomgun_lc | Chip Amps | 9 | 16th September 2005 09:52 AM |
