Cheap and simple Open Baffle (a la MJK)
Old 20th March 2012, 08:08 PM   #11
R.I.P.
Originally Posted by Tea-Bag View Post
Have you considered the highs might stink?
The graph's dont look too impressive.
Vifa TC9FD-18-08 3-1/2" Full Range Paper Cone Woofer 264-1062
http://www.parts-express.com/pdf/264-1062s.pdf
Given the above I don't think so but off axis response would be limited,
like all FR's. Yes you could add a tweeter but you'd be moving away
from MJK's basic premise. The off axis responses in the PDF suggest
a slightly off axis response could be flatter and a respectable power
response. Compared to similar drivers the highs won't suck at all.
For a real graph (Zaph's) the response looks very impressive to me.
I guess an option would be to look at this co-axial if a tweeter is needed:
http://www.parts-express.com/pdf/264-827s.pdf
Might work well with a zobelled bass/mid and high 1st order (series) x/o
to hit ~ 2nd order L/R acoustic around the x/o point, drivers out of phase.
rgds, sreten.
(Yes PE do do the Vifa, so that would be $120 a pair delivered free ....)
Old 20th March 2012, 10:19 PM   #12
ttan98 is offline ttan98  Australia
Sreten,
Vifa TC9FD-18-08 3-1/2" Full Range Paper Cone Woofer 264-1062, from the spec. sheet the eff. is about 84dB and a PAIR in parallel should give you about 90dB not 93dB as you implied.
BTW, I use Mark Audio Ch-70 mark III the eff. is about 85.5dB and a parallel PAIR in dipole config. in a box gives me about 91.5dB good enough for my 10W tube amp.
Old 20th March 2012, 11:51 PM   #13
R.I.P.
Originally Posted by ttan98 View Post
Sreten,
You need to read more carefully, the 93dB refers to the pair of suggested
bass units, not the driver itself. You have to mean bipole as opposed to
dipole, and quite frankly what has that got to do with this OB thread ?
Seems your just lazy and haven't worked out what this thread is about.
rgds, sreten.
Old 21st March 2012, 01:35 AM   #14
rgds, sreten.
I know you have contributed a lot to this forum this does not mean you can start accusing whoever you want. I may have misread your post you don't have this rude it does go very far.
Goodbye I leave this forum to you and your follower.
Old 21st March 2012, 03:57 PM   #15
R.I.P.
Hi, Your right, i was unecessarily rude, I apologise, rgds, sreten.
Cheap and simple Open Baffle (a la MJK)Hide this!Advertise here!
sub amp question for MJK open baffle pforeman Full Range 7 15th May 2009 07:19 PM
are there simple PLLXO soltuions for open baffle setups? freddi Full Range 3 11th February 2009 08:21 PM
Open Baffle Fun with Cheap Goldmine Speakers wrenchone Full Range 4 5th September 2008 08:07 AM
Open Baffle Line Array - using cheap drivers giambi77 Multi-Way 4 26th January 2004 09:29 PM
Uber cheap open baffle line arrays -- almost done ryoshu Multi-Way 5 1st July 2003 11:31 PM
Copyright ©1999-2017 diyAudio
