Manger MSW & Moongel - diyAudio
Old 17th March 2012, 04:39 AM   #1
Default Manger MSW & Moongel
I am using Manger drivers for more than a decade and still find their basic sound quality fascinating. But they are not perfect: dispersion of HF, notch in frequency response at around 800 and 1600 Hz and high distortions at that frequency range. Manger developed new speakers but there is no upgrade of the driver itself for more than 2 decades.
I found Moongel .: RTOM Corporation :. which is used for damping drums and thought to try it on the MSW as they are quite cheap. No effect when used in the periphery of the outside or in the center of inside. But there was some positive effect when the moon gel was applied at the center of the MSW on the frequency response and much more significantly on the distortions levels of the midrange. (filtered at 400HZ)
yellow: MSW alone
dark violet: MSW + Moongel at center
Old 17th March 2012, 04:46 AM   #2
One thing I forgot to mention: they simply stick to the surface but can easily be removed (no glue required). 1/2 pad had close to the same effect as a hole one. And I would not write about it if it would not sound better - I guess 6% distortion is noticeable.
I expect that other bending wave designs could also profit from this sticky gel.
Old 17th March 2012, 08:52 AM   #3
Draki is offline Draki  Macedonia
Very interesting.
Are there no side-effects due to increased mass?
Subjective differences between moongelled vs plain?
Old 17th March 2012, 11:01 AM   #4
Joachim Gerhard's Avatar
I worked out a similar solution. It is a combination of mass and spring what is necessary.
Old 17th March 2012, 06:01 PM   #5
The MSW is suspended/fixed in the center with a semisoft material on the inside of the driver (they call that structure Hochton-Reflexionsdämpfer). So adding a mass to the center should have less effect than adding it to the periphery. But I found no effect of the gel pads except when applied to the center. I did not investigate the effects on low frequency as I used a digital filter at 400 Hz. I did not investigate the lateral behavior yet.
It would look better if the Moongel could be attached to the inside between the membrane and the damper but that means to deconstruct the MSW.
Sound wise there is a better tonality of instruments and voices - more natural. Also there is better defined depth of the sound stage.
Old 17th March 2012, 06:11 PM   #6
hm is offline hm  Europe
hm's Avatar
Hello,
did the step response change?
i made a construction which fill the 1,5 kHz dib,
but you need two MSW each, the POSAUNE take a view,
never built but theoretical a best fullrange MSW solution, max. 96 dB
http://www.hm-moreart.de
Old 17th March 2012, 06:52 PM   #7
There is a small change in the step response
yellow: MSW alone
Old 17th March 2012, 07:58 PM   #8
The 1,6kHz hole is an acoustic destructive interference that comes because the signal is put in over a high diameter voicecoil. That hole does not create distortion as such.
Here are my results before and after modification. The distortion is THD at quite high volume. It is made up mostly of second. A measure of chaotic behaviour that can also be interpreted as a DC offset.
Old 17th March 2012, 08:01 PM   #9
The driver is 20 years old in an inherited Audio Physic Medea designed by me. It looks like brand new.
Old 17th March 2012, 08:36 PM   #10
with moongel app the step response goes worse ...
"acoustic destructive interference"
no way , where should the delay come from? it must be a helmholtz-type resonance that is coupled to the diaphragm and steals energy ...
btw in nearly every second posts of yours I´m detecting false conclusions , you electronic guys should better stay at your main pro?fashion
greetz - the almighty blechkasten
FS: Pair of Manger MSW Drivers boidos Swap Meet 9 2nd June 2011 06:40 PM
1 Pair Manger MSW Drivers Tenson Swap Meet 5 2nd February 2007 05:01 PM
Manger MSW Bending Wave Driver ShinOBIWAN Swap Meet 34 7th December 2006 01:49 PM
Good woofer pairings for a manger msw RyanC Multi-Way 39 21st July 2006 01:57 PM
Manger MSW and Eton 11-581/50 HEX Plans Calebay Full Range 37 22nd March 2004 06:05 AM
Copyright ©1999-2017 diyAudio
