Design suggestion for 4" Airborne driver please....
Old 15th March 2012, 06:22 PM   #1
sagamotto is offline sagamotto  Canada
Default Design suggestion for 4" Airborne driver please....
Hello all...
Have anyone here have any experience with the Airborne driver from Solen.ca?
12cm Wood Cone, HR124B8-10L
http://www.solen.ca/pdf/airborne/hr124b810l.pdf
These driver has very high build quality and I have 4 of them, can someone suggest a cab design for these?
Old 15th March 2012, 06:25 PM   #2
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
I haven't checked properly, but on a quick look at the spec. sheet, it should go in FH3 reasonably easily. I'd want to damp out that ~7KHz peak though.
Old 15th March 2012, 06:53 PM   #3
hi scott, how are you ? thks for the quick response.
A notch in between 7k is for sure needed, but what about smaller size design?
Old 15th March 2012, 06:56 PM   #4
Scottmoose's Avatar
You'll need to narrow it down: what do you want?
Old 15th March 2012, 07:44 PM   #5
chrisb is offline chrisb
if you're thinking of asking if the FH3 can be scaled down (or up) for different drivers, don't (ask that is)
we haven't ourselves (yet) tried drivers smaller than say any of the Mark Audio 70mm series, or Fostex FE126, but there's likely no reason the Airbornes couldn't work well enough - but both the pronounced 7kHz spike and quick drop off above would need some type of attention
actually, I'd be inclined to think the latter (roll-off above 7K) might be more of an issue than the peak itself - EQ might not resolve it satisfactorily
since you have 4 of these, have you had them playing yet in any type of test enclosure, or heard them elsewhere? i.e. what is your impression of their top-end?
if it turns out that they do need some boost in the top end, I'd be more inclined to think about a small MTM and XOing them around 4-5K to a small dome tweeter.
kinda burnt out - taking a break
Old 15th March 2012, 07:56 PM   #6
Scottmoose's Avatar
Agreed. Depends on the type & size of the enclosure desired.
Old 15th March 2012, 07:56 PM   #7
Sorry scott, I didn't mention my point well. But as I was posting here, I had alittle time to google on some very interesting cab design. One of them was about Multiple-Chamber Aligned in Parallel Speaker System(MCAP-CR).
mcapspeakers
One of the design mention caught my attention is a compact three and four small chamber formulate into a cubical box. They are compact and systematic....an advance BR bookshelve speaker.
MCAP-CR_Suggested_Cabinets
scott, what is your opinion on this type of box design, do they sound as good as they say it would ?
Old 15th March 2012, 08:17 PM   #8
mcapspeakers
can you say "jenga"? - lots of "interesting" speaker enclosure designs out there - speculation as to how one might sound can go only so far
Old 15th March 2012, 09:22 PM   #9
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
Or something less polite.
I'd start with something simple, but maybe that's too easy? The drivers in question sim. fine in a 10L ported box, so why not start there?
jeff
Old 15th March 2012, 09:43 PM   #10
jeff
can't help but think of the old SP lyric "in spite of my rage, I'm still just a rat in a cage"
for some reason, Olson / Nagaoka manifold types intuitively make more sense than this maze of resonant cavities
but far stranger things have "worked", so who knows - it'd be fun to try and model it though
Design suggestion for 4" Airborne driver please....Hide this!Advertise here!
Airborne driver woody Full Range 0 2nd September 2011 01:15 AM
Driver suggestion obbelix Subwoofers 10 24th October 2007 11:07 PM
Driver suggestion. Big Kev ! Subwoofers 61 12th August 2006 05:16 PM
All about Sub's , Good sub design , 12" driver . darkm4n Subwoofers 3 3rd December 2003 04:44 AM
