Frugal horn driver's
Old 14th March 2012, 07:06 PM   #1
kendt is offline kendt  Canada
Default Frugal horn driver's
I have a pair of these and really like them.Proraum Vertriebs-GmbH | Shop | Midrange Drivers | AUDAX HM130Z10
I was wondering if they would work in the frugal horn mk3's
Old 14th March 2012, 10:29 PM   #2
chrisb is offline chrisb
not a lot of clearance to the internal divider - you might want to add another layer of material to step the driver out a bit, but it should fit
"work"? - likely yes, although expect to need to play with stuffing of line below the driver - the niftiest way I've seen to accommodate for that is to make the top removable
judging from the graphs, even if you do get acceptable LF response, you'll very likely need a tweeter filling in from around 5-6K up - if you don't have an aversion to small domes, could be as simple as the DW74M or TFM025 F1 - or to as much as you wanna spend (Heil AMT or BG ribbons, anyone)
if doing something as silly as the AMT, be sure to securely attach to the enclosure, and add extended base plate or outriggers for stability.
like my mind, this space intentionally blank
Old 15th March 2012, 01:20 AM   #3
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Should go in from a spec. POV, purely in terms of the load. Can't comment on what it'd sound like of course, only one way to find that out...
Old 15th March 2012, 11:17 AM   #4
I have always really loved the aerogel drivers.If they would mate well with the boxes i think with the addition of some tweeters they'd make a very nice sounding speaker. Could be a very intersting project.
Next question
Are there plans available yet for the mk3. I have been following the threads and haven't come across any.
Old 15th March 2012, 11:39 AM   #5
Never mind, found em,.....
Frugal horn driver'sHide this!Advertise here!
Frugel-Horn Sub-Woofer dbailey Full Range 31 28th May 2017 05:52 AM
Frugal Horn and Audio Nirvana Pemo Full Range 2 21st November 2010 05:43 PM
Frugal horn build djdaveysprocket Full Range 16 3rd May 2010 06:36 PM
fe 127 & frugal-horn mcr483 Full Range 2 26th December 2009 08:25 PM
Single Driver Horn Base Port from Frugal Horn EmergencyDpt Swap Meet 0 26th October 2008 01:24 AM
