Wanted 12" full range drivers must handle in excess of 100 watts RMS . 8ohms prefer. Has anyone got any suggestions please .I perhaps should have said I have made tapered horns for domestic use it is only running at 4.5 K at the moment . Very prototype at the moment Thanks
pedro11 Last edited by pedro11; 10th March 2012 at 08:16 PM. |
#2 |
Seems many folks like Beta 12LTA and it fits your requirements thus far.
![]() http://www.eminence.com/pdf/Beta_12LTA.pdf IG |
#3 |
i couldn't get the Beta 12LTA, so i bought 2x Fane 12-200LT. it was likened to the eminence driver in a thread i found on here. i've not done a whole lot with the driver yet to really make sufficient judgement on their sound.
#4 |
Thanks guys .
it all started last year . I made tapered cabinets convex fronts & convex rears . The 3 way compartments are all separate from each other .Then I thought can I make a tapered horn for the bass horn out of 1/16" ply it goes through the back of the cabinet & then a right angle upwards .Thats when the headaches started . Have you ever tried to roll ply cross grain you have to wet it for 24 hours . I then coated the inside with 3 layers of resin which has a least tripled the thickness very inert . I can take it in & out to try different drivers . 3 so far .Then another brain storm came along is there a driver about 25hz to 20k available 12" diameter . So that is where I am at the moment . I am very pleased with the sound. Peter |
| Electro-voice SP-12B 12" full range drivers | analogKidA | Swap Meet | 0 | 2nd October 2011 06:50 PM |
| Low level body/weight presence wanted: Can 12" full range deliver? | VanJerry | Full Range | 411 | 2nd March 2010 07:12 AM |
