Ladies & Gentlemen - The Emken - Page 6 - diyAudio
Old 16th March 2012, 03:21 AM   #51
frugal-phile(tm)
planet10's Avatar
Someone asked me to check that one out... i suggested 50 litres aperiodic to 400 litres sealed.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 16th March 2012, 03:38 AM   #52
GM is online now GM  United States
GM's Avatar
OK, but not knowing the details of the Emken, how does it sim in it?
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 16th March 2012, 07:31 AM   #53
JRKO's Avatar
Send a message via AIM to JRKO
Originally Posted by KaffiMann View Post
What are they like off axis? Much beaming?
If they are FLAT to around 60hz i am sold! (Got a sensitive sub, Don't like eq much.)
Larger drivers tend to beam at higher freq. I have them with no toe in at the moment and the sweet spot is fairly narrow. This should widen significantly with toe in and moving the super tweeters around also helps with fine tuning
As for 60hz its loud and proud using this web page - http://www.ronelmm.com/tones/
It goes much lower too but its 0730am here so the neighbours wont appreciate met trying to simulate 32hz at high volume!!
If I'm not making noise, I'm making something to make noise
Old 16th March 2012, 07:42 AM   #54
frugal-phile(tm)
planet10's Avatar
There is always some estimation going on with the "miniOnken" sims. A slightly peaked response which gets damped down by the "R" in the vents.
12LTA should roll of smoothly with F3 est at 55 Hz, F10 40 Hz.
Put the Fane in and you get a couple or 3 more Hz extension buy +2 or 3 dB peaking at 60 Hz. If you took it further you could slide some open cel foam into all the slots and get something usable.
dave
Old 16th March 2012, 12:21 PM   #55
KaffiMann's Avatar
...Was thinking about the Hawthorne iris 10"
I have the Sterling version of this driver.
OB's are nice and dandy and all, but it would be nice to be able to cut away maybe 1 or 2 drivers per channel. I would also be able to have a cleaner signal path with less junk and eq in general.
The 'ken variations for different types of drivers are not really dependent on a fullrange is it? Should be possible to make something more fun with maybe a 10-15" coaxial setup, it would still be point source, you'd need a crossover, but you can easily get away with something like the passive line level designs from marchand.
Old 16th March 2012, 04:56 PM   #56
JRKO's Avatar
Theres the obvious 2" size difference - that and every 'ken box is designed very specifically around a specific full range driver and its own peculiarities. As far as I know its more a happy coincidence if it works with other drivers but I'm probably wrong (?Dave?)
The Hawthorne is a tweaked Eminence DC driver I believe. Where does the crossover happen? Is the 10" driver a 'mid/bass' driver or a bass driver?
Old 16th March 2012, 05:32 PM   #57
frugal-phile(tm)
planet10's Avatar
Hawthorne iris 10" Sterling
Data?
dave
Old 16th March 2012, 06:10 PM   #58
Just wondering how they would sound with a Maggie tube amp of about 8 watts per channel? Thanks. Curt
Old 16th March 2012, 06:27 PM   #59
JRKO's Avatar
lend me one and i'll tell you I REALLY want a valve amp for these babies
Old 16th March 2012, 06:47 PM   #60
I'd have to pull it from the console. Sorry! I'm planning a speaker project to run of the aux with a full range driver curt
Can you gentlemen help me design a Zobel circuit? Broadwayautoclinic Multi-Way 5 16th June 2011 10:04 PM
Hi Ladies and Gents Steven-H Introductions 1 17th January 2007 05:18 PM
Swinik VS Quad -- where is your Bridge, gentlemen? Wavebourn Solid State 20 16th October 2006 08:10 AM
Hello ladies(?) and gents Duck-Twacy Introductions 3 16th January 2004 08:41 AM
Ladies in audio Doug Everything Else 8 2nd February 2003 11:21 AM
Copyright 1999-2017 diyAudio
