Ladies & Gentlemen - The Emken
Old 17th September 2012, 06:19 PM   #521
sippy is offline sippy  United Kingdom
Here's a couple more pics.......both enclosures are now built, but need a bit of a grobble to get the bevels even.
They should be making noise Very shortly.
Old 17th September 2012, 07:18 PM   #522
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally Posted by sippy View Post
... brace - might have taken a bit too much out when cutting holes....
It is fine, room even for a few smaller holes.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 17th September 2012, 09:04 PM   #523
My Em's were stacked in my kitchen, Girlfriend comes in through the door and says:
"Good gods Darrell, those are *expletive* huge!"
"That's a pair love, but that's what they might look like with LF cabs"
"Your off your *expletive* trolley man"
So yes JKRO, I can see why your better half put the kybosh on such an idea.
Old 18th September 2012, 11:04 AM   #524
Vix is offline Vix  Yugoslavia
Vix's Avatar
Well, you can say "Huge size, Huge joy" (and vice versa)
Old 18th September 2012, 11:30 AM   #525
Or "End of tenancy,very homeless "
Old 18th September 2012, 12:07 PM   #526
JRKO is offline JRKO
JRKO's Avatar
Send a message via AIM to JRKO
one of many ideas. The Beta 15's are coming......
There's enough wood in a pair of Emkens you can probably make a nice sized
makeshift dwelling and run one of Dave & Chris' smaller designs!
If I'm not making noise, I'm making something to make noise
Old 18th September 2012, 12:43 PM   #527
makeshift dwelling and run one of Dave & Chris' smaller designs!]
Or knock em down, make smaller design and move in with gf. Half the cabinet hight with same footprint would be ok for my domestic setting.
I'm going to have a look at some washers for mounting the 12lta's, as my fancy marine grade stainless cap head bolts (2.67 for 16!!!) 'heads' don't fit in the frame. Its either a stack of washers with a flat ground on them to space the head up OR grind the outer flange of the basket.
Is the latter a truly bad idea, obviously I'd have to wrap the driver up to stop swarf ingress.
Old 19th September 2012, 08:53 AM   #528
JRKO's Avatar
Its not pretty (does that even matter with the Emken?) but I use a 1 inch washer to spread the force/pressure of the bolt.
I'm hoping to find someone to make me a ring of 2-3mm steel the same dims as the 12LTA to act as a clamp.
Old 19th September 2012, 02:51 PM   #529
I'm doing a few bits on them now, the battens in the top and bottom so the back can seal (an oversight in the excitement of them getting together) and some blocks for the rear panel / brace interface.
Then I have to either:
1: grind flats on 80 (yes 80) washers to mount the Lta's.
2: make spacers from some hard plastic I've had lurking for a while.
I can live with the cabinets being unfinished, but not to mount the Lta properly would hack me off proper.
Old 19th September 2012, 11:02 PM   #530
Etocynned is offline Etocynned
Put all 80 washers on a long bolt and tighten a nut on it.
laying the nut along a belt sander will grind them all at the same time.
Altec Lansig computer speaker amp, Paradigm atomss, Altec computer sub, Windows PC source
Ladies & Gentlemen - The EmkenHide this!Advertise here!
Can you gentlemen help me design a Zobel circuit? Broadwayautoclinic Multi-Way 5 16th June 2011 10:04 PM
Hi Ladies and Gents Steven-H Introductions 1 17th January 2007 05:18 PM
Swinik VS Quad -- where is your Bridge, gentlemen? Wavebourn Solid State 20 16th October 2006 08:10 AM
Hello ladies(?) and gents Duck-Twacy Introductions 3 16th January 2004 08:41 AM
Ladies in audio Doug Everything Else 8 2nd February 2003 11:21 AM
