Ladies & Gentlemen - The Emken
Old 11th September 2012, 08:18 PM   #501
Bob Brines is offline Bob Brines  United States
Bob Brines's Avatar
Originally Posted by planet10 View Post
The goal is to push panel resonance as high as possible. They results from Tappan's AES paper
dave
Right, but not my point. A single large hole should give you nearly the same cross panel strength as a lot of little holes. A large round hole is just as effective as a window brace. And note that I stated that panel stiffening is more important that cross panel bracing, which is what you just said.
My current bracing scheme is a crosswise brace at the top and bottom of the driver to tie the panels together and longitudinal braces ( 12mm x 50mm) from the bottom of the driver to the bottom of the cabinet, i.e. picture #5 in your quote.
Bob
Old 11th September 2012, 08:30 PM   #502
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
A single large hole will provide near the same strength, but does not provide the direct solid path from driver magnet to back panel and does not provide the surface area to break up side-to-side standing waves.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th September 2012, 10:21 PM   #503
sippy is offline sippy  United Kingdom
A well placed brace can work wonders, I learnt this on my first diy build back in '97 - a pair of DB 9's from the part kit and artical in HFN&RR, 2 off cross braces spaced un-equally and an angled bottom panel to quell standing waves.
One thing I am certain of is the need to tie the front and rear baffles together, holding a 12lta while its running test tones OR music gently really brings it home why this feature is there.
My front to back braces are all marked out now :-)
Old 12th September 2012, 06:03 PM   #504
Report:
All panels cut including rounding over the holes in the brace
All stock ripped for vent spacers and battens.
So, I'm waiting for the 7pm re-run of the Simpsons then its glueing and pinning the sides together.
Neighbours have been asking what I'm making, guesses ranging from book cases to cupboards, the look on their faces when given the answer 'Loudspeakers' has been priceless, even more so when I showed 'em a front baffle an a top.
(evil laugh) HaHaHaHa
Old 12th September 2012, 06:19 PM   #505
JRKO is offline JRKO
JRKO's Avatar
Send a message via AIM to JRKO
Rock on the weekend!! I'll be interested to hear the difference the alt. tuning makes.
soon there'll be 3 pairs out there
If I'm not making noise, I'm making something to make noise
Old 12th September 2012, 06:39 PM   #506
chrisb is offline chrisb
Originally Posted by sippy View Post
Report:
emphasis on the Loud part - which they'll be experiencing soon enough
hope you find them worth the wait
like my mind, this space intentionally blank
Old 12th September 2012, 06:40 PM   #507
Aye, that there will - so we're still part of an exclusive club. It just struck me, I could / can not only tune the vents symmetrically, but asymmetrically as well.
Dave's thoughts on this would be welcome.
Old 12th September 2012, 07:18 PM   #508
frugal-phile(tm)
planet10's Avatar
When Chris shortened the vents i left myself some opportunity to do some trick tuning. Stay tuned.
I don't know what different length vents would do. Some smoosh of the tuning frequency
dave
Old 12th September 2012, 09:15 PM   #509
chris661 is offline chris661  United Kingdom
chris661's Avatar
http://www.diyaudio.com/forums/subwo...t-tunings.html
Smooshing of the tuning frequency would appear to be correct.
Probably worth messing around with, anyway.
Chris
Old 12th September 2012, 09:49 PM   #510
JRKO's Avatar
what you going to power them with Sippy?
I thinking of a small class A amp - SEWA looks nice. Really simple before heading into the realm of Papa Pass
Ladies & Gentlemen - The EmkenHide this!Advertise here!
Can you gentlemen help me design a Zobel circuit? Broadwayautoclinic Multi-Way 5 16th June 2011 10:04 PM
Hi Ladies and Gents Steven-H Introductions 1 17th January 2007 05:18 PM
Swinik VS Quad -- where is your Bridge, gentlemen? Wavebourn Solid State 20 16th October 2006 08:10 AM
Hello ladies(?) and gents Duck-Twacy Introductions 3 16th January 2004 08:41 AM
Ladies in audio Doug Everything Else 8 2nd February 2003 11:21 AM
