#491 |
It may also be worth rounding the interior edges of the cuts - less reflective flat surfaces
In the interests of full disclosure JRKO = James Rupert Kingsley Osborne. And yes, my parents will pay for it when I choose their retirement home |
#492 |
frugal-phile(tm)
A circle leaves a strong brace, but you could use heart shapes as long as you hit the 30-40% holes target.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#493 |
HI Dave. Any notes or thoughts on the Emken in its side vented state? How did it go down at 'FEST 2012?
James
#494 | |
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#495 |
If you look at a single round hole in a brace as four cantilever bridges, you'll see that this makes a pretty good brace without a lot of trouble. Panel stiffening, however, is far more important than tying panels together. The "holey brace" does both, but a couple of dowels between the panel stiffeners would be much easier and nearly as effective.
Bob |
#496 |
The end of another half days work (ish):
All large panels cut, driver holes routed though no rebate as the t-nuts would not have enough material round them for my liking - Matt spotted this and said best bet is to laminate an extra panel to make said at a later date. Tomorrows jobs: Chop vent walls / extensions to length, cut holes in brace / driver cut back (I had a lucky find - 2 thin jig-saw blades in the bottom of my tool box), rip stock for spacers / battens, sink t-nuts and start slopping glue, pinning and clamping. There's a slim chance they will be in operation by the weekend, if not by the end off. On the subject of the holes, would one actually be able to hear this 'Eigenmode'? How about a 90deg round over but alternating the side that's rounded? Or is this a bit too much fuss? |
#497 |
Welllllll....
P10 design sheet calls for front to back and side to side braces, the latter sit in the lower half of the enclosure - I guess once the port length has been sorted and these cross's added, the upper walls can be braced with dowels = not cause reflections back through the drive units cone. |
#498 |
Well done mate!! I would say do what you can - I doubt either of us would hear the difference but its nice to know you've done what you could.
Just get 'em finished, heft them into place, plug 'em in and let rip!! Maybe warn your neighbour you will be playing 'enthusiastically' Pick your first track carefully - something with great attack will put a grin on your face
#499 | |
frugal-phile(tm)
![]() dave
#500 | |
frugal-phile(tm)
With 2A3 SE on the garage apron (ie outside, no room) they were at their best yet. dave
| Can you gentlemen help me design a Zobel circuit? | Broadwayautoclinic | Multi-Way | 5 | 16th June 2011 10:04 PM |
| Hi Ladies and Gents | Steven-H | Introductions | 1 | 17th January 2007 05:18 PM |
| Swinik VS Quad -- where is your Bridge, gentlemen? | Wavebourn | Solid State | 20 | 16th October 2006 08:10 AM |
| Hello ladies(?) and gents | Duck-Twacy | Introductions | 3 | 16th January 2004 08:41 AM |
| Ladies in audio | Doug | Everything Else | 8 | 2nd February 2003 11:21 AM |
| Page generated in 0.80927 seconds (100.00% PHP - 0% MySQL) with 10 queries |
