Ladies & Gentlemen - The Emken - Page 21 - diyAudio
Old 4th May 2012, 11:42 PM   #201
GM is offline GM  United States
GM's Avatar
Originally Posted by gafhenderson View Post
.......i didn't want his old crap *manly tears*
Hopefully, they were grabbed by someone that could appreciate them.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 5th May 2012, 02:05 AM   #202
frugal-phile(tm)
planet10's Avatar
like this?
Certainly something to try.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 5th May 2012, 04:12 AM   #203
GM's Avatar
Originally Posted by chrisb View Post
- for serious music listening, I'd probably want to properly XO them (circa 3500-4k?)
Good guess! In theory, for best overall on/off axis blend = ~3553 Hz using published specs.
GM
Old 5th May 2012, 05:01 AM   #204
frugal-phile(tm)
planet10's Avatar
am i actually doing that whizzer trick properly? any other ideas to try?
The official trick is a slice of low desity foam on edge wedged between the edge of the whizzer & the cone.
Your FR curves are measuring the surface, but any benefit will show up on the bottom (20-50 dB down).
dave
Old 5th May 2012, 07:48 PM   #205
sippy is offline sippy  United Kingdom
Blimey,
Things have really moved on.
Interesting to see the graphs showing where the dips in response lay and the way cone treatment shifts things around.
Is the plugs lack of parallel section below the the cone / voice coil former causing issues?
Old 5th May 2012, 09:33 PM   #206
frugal-phile(tm)
planet10's Avatar
its actually better in most respects than the standard bullet shape was. i got very little improvement from the conventional bullet shape and i had an hunch that the whizzer was just too big for it to work well. so i've flared it out at the end as i've seen in a few other classics of the full range world and the difference was very impressive.
The shape has me thinking of mounting a modified FT17 on the end of the phase plug (bolt thru the pole vent to hold it in place.
dave
Old 6th May 2012, 12:09 PM   #207
JRKO's Avatar
Send a message via AIM to JRKO
Dual Concentric Eminence 12LTA? I know the tweeter is normally mounted on the same baffle as the 12LTA - I wonder if you could get it to fit at the same plane within the whizzer cone. 2 Questions:
1)Would there be time/phase issues with mounting a tweeter there?
2)Would the fact that the tweeter blocks most if not all of the whizzer's direct output be a problem?
I'll hold off letting the the FT17H into the baffle to see what you guys measure on the DC version
Will be playing with 'pluff' around the whizzer and maybe some packing noodles cut into wedges and then some polystyrene as its a bit firmer. I don't think that I'll be painting anything on the cones at the moment. Maybe enABL dots later
If I'm not making noise, I'm making something to make noise
Old 6th May 2012, 02:48 PM   #208
frugal-phile(tm)
planet10's Avatar
1/ can't be worsr than fitting it on the baffle.
2/ one should be able to make a tweeter-plug of very similar shape to gaf's. One would start by dremeling off the flat mounting part of the plastic bezel.
For this ap, a very compact horn is required and the FT17 is the most suitable i have.
dave
Old 6th May 2012, 02:59 PM   #209
jimbro is offline jimbro  United States
With a fs of 5k guess you couldn't use the ft17 for the 3553hz GM suggested. What would the xover point be? Would the rule of twice fs apply? If so 10k?
Old 6th May 2012, 05:02 PM   #210
tuxedocivic's Avatar
I'm not familiar with that tweeter, but what is the driver type? Compression or direct radiator? I looked up quickly and Fs is 2600hz. Probably can go close to it depending on filter and the tweeter.
Can you gentlemen help me design a Zobel circuit? Broadwayautoclinic Multi-Way 5 16th June 2011 10:04 PM
Hi Ladies and Gents Steven-H Introductions 1 17th January 2007 05:18 PM
Swinik VS Quad -- where is your Bridge, gentlemen? Wavebourn Solid State 20 16th October 2006 08:10 AM
Hello ladies(?) and gents Duck-Twacy Introductions 3 16th January 2004 08:41 AM
Ladies in audio Doug Everything Else 8 2nd February 2003 11:21 AM
Copyright 1999-2017 diyAudio
