#121 |
Interesting! First off glad you didn't say you decided to burn them
Ok from a quick search of your comments on the Silver Iris I found: 'lack of any midrange definition, and the audible resonance train from the midrange up to the top of the 15s BW which is, i am sure, the major contributor to their "boxiness"............Boxy sound = sound that sticks to the speakers. No matter the cause..........Midrange is quite lacking......suffer from the same severe cone resonances as the Silver Iris......i feel that the ability to dissappear is important. My primary speakers (Fonken with FE127eN) do a really good job, the speakers i'm evaluating right now (Silver Iris on OBs) don't. On the back of this I played some test tones from here Stereo System Test & Analysis Tones by Nino B. and there is a noticeable dip in output at 150Hz as opposed to 125Hz and 250Hz. My drivers have several hundred hours on them, a dustcapectomy and a phase plug which does wonders for the inbuilt resonance and peaky, hi end of the 12LTA. I know this was designed with potential PA work in mind but I am confident they will beef up with some boundary reinforcement from both floor (or stage) and walls. My room is bigger than Sippy's but WAY smaller that ChrisB's space! They are 2/3 up the length of the room firing down the length and bass is tight and dry but I may as well try them against the wall as well as I miss the bigger badder bass I had with 2 Beta 15's not so long ago ![]() They definitely need a tweeter up top and as noted I use a FT17H with a single 1uF cap. This seems to 'bulk' the sound up a bit as well. I love the iPod-Dac-40yr HK receiver setup but can say the box would benefit from something bit further up the scale Especially if the ipod was playing straight from its headphone output but I can imagine you or ChrisB doing that - it sounds awful that wayThanks for the work so far guys - Can you give us a 'for home use' critique as well when/if you are able to get them into a living room? Get well soon Sippy
In the interests of full disclosure JRKO = James Rupert Kingsley Osborne. And yes, my parents will pay for it when I choose their retirement home |
#122 |
Okay quick question here, weve got surgery going on a pair of these, dustcapectomy and phase plug implanting.
anyone familiar might know? Are these drivers a cantidate for the ENable mod?
System: Hitachi HT-320, HK 330a, Energy 3.1e speakers and xbox360, android phone headphone out for hirez FLAC playback. |
#123 | |
someone has tried it. 'bassrogue' be his name. i'm about to do it on some fairly similar drivers too. worth a try tbh. given the sound feedback from the 12lta's they sound similar to my alternatives, and from my (amateur) listening i think various cone treatments will do them a lot of favours. phase plugging mine made them into a completely different driver. Last edited by gafhenderson; 3rd May 2012 at 03:14 PM. |
#124 |
I'm sure I read in Godzilla / JRKO's thread that chap had done the 'damar' mod.........
i see from my email notification that ive been beaten to mentioning it |
#125 |
Wow! gafhenderson, you're on the ball with that pic! I'm not sure if that is the 'official' enable pattern or not, but I'm pretty sure Planet10 has said he has one.
I'm holding out for a few more impressions from him on the Emken cabinet thou
#126 |
I make no comment - I don't have the drawing or the drivers yet, though 'tinker with to taste' seems apply.
Are your tweeters still on top of the box JRKO? Inside or out? |
#127 |
yup topside and outboard.....
#128 |
Let's say the first date certainly revealed there's no disguising this driver's provenance as a PA driver, and yes it reminds me of many of the things I didn't care for with both the Silver Iris coax (with the cheaper compression driver) and the Hammer Dynamics Super12 - both of with employ Eminence based drivers.
I can image no real problems with these used for bass augmentation in a FAST , but even thought an emergency dust-cap-ectomy and phase plugs helped quite a bit, I still found some severe colorations in the vocal range that made them particularly fatiguing, and that have nothing to do with the bass tuning of the box. XO them over low enough ( say 500-800Hz?) to a larger compression horn tweeter like those in link by gaf and a healthy listening distance would be my choice. In the photo that Dave will eventually post, you'll see a pair of old KLH (17?s) mounted on the wall - while nowhere near as efficient as the Eminence, or capable of projecting 50-60ft , these are so much more listenable at my typical working / listening distance of 8-12ft the game's afoot
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#129 |
Indeed!
You'll need to run the drivers in a good few hours for some of the honk & harshness die back some - even with the dustcapectomy and good phase plugs. Some advocate padding the back of the whizzer for this although I've not gone that far. Would be good to hear how you get on with them in 'home' usage that I assume most of the builders will be interested in. I guess you and Dave may be more 'mid sensitive' than the rest of us as you specialise in smaller full range drivers/speakers and their sound - does that even make sense? A few questions if I may: Are your comments PA-centric or general? - I think most those currently looking at these will be wondering about home use What are the negative coloration's you hear? Is the 'healthy distance' recommendation only in PA usage or in general home use - or even a 'stay well clear' warning? Ooh could you recommend a track that I can find (on spotify say) that we can compare notes on for the mid issues?
In the interests of full disclosure JRKO = James Rupert Kingsley Osborne. And yes, my parents will pay for it when I choose their retirement home Last edited by JRKO; 3rd May 2012 at 05:45 PM. |
#130 | ||
frugal-phile(tm)
I'm pretty sure that break-in and treatment will go a long way towards fixing the problems. Better room and ancilliary gear won't hurt rither. These are coming up the mountain (i live near a mountain top -- most of the mountain under the pacific) so i can staty tuning them up ... reminds me, i need to get Bernie to bring back the RH84. Quote:
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
| Can you gentlemen help me design a Zobel circuit? | Broadwayautoclinic | Multi-Way | 5 | 16th June 2011 10:04 PM |
| Hi Ladies and Gents | Steven-H | Introductions | 1 | 17th January 2007 05:18 PM |
| Swinik VS Quad -- where is your Bridge, gentlemen? | Wavebourn | Solid State | 20 | 16th October 2006 08:10 AM |
| Hello ladies(?) and gents | Duck-Twacy | Introductions | 3 | 16th January 2004 08:41 AM |
| Ladies in audio | Doug | Everything Else | 8 | 2nd February 2003 11:21 AM |
