Ladies & Gentlemen - The Emken
Old 24th April 2012, 03:15 PM   #91
Godzilla is offline Godzilla  United States
Godzilla's Avatar
I suppose it's all about a smooth blend between the 12" driver and the compression tweeter of choice for this to be successful. I thought about it and love the whole coax idea but opted for the 'more traditional' wide range approach plus helper woofer and tweeter. The sound is very smooth this way (crossovers outside critical ranges) allowing the 12lta to simply play full out (showing off it's raunchy, fun, dynamic character) without circuits being in the way. I love the purity and simplicity of this type of 3-way.
Whether OB or Sealed, the 12lta is a winner... I'd LOVE to hear the Emken and adopt one for my listening room but i'm in divorce limbo at the moment. I am very enamored by the 12lta regardless of its flaws. It ROCKS like no other full ranger i've encountered.
Old 24th April 2012, 05:51 PM   #92
chrisb is online now chrisb
Originally Posted by JRKO View Post
Awww Dave! Tell Chris to stop painting the thing and put it together. You guys are gonna make me look bad (not a hard thing ) I started months ago and you guys will have a fully finished version before I do!!!!
In fact the most time consuming part so far has been fitting and drilling all those holes in the full length and lateral bracing - the CNC & operator are not always available after hours. Even though it's actually faster by hand with a 1/2" power drill than a belt driven drill press - no matter how large the motor, there's way too much slippage on the latter, and moreover you only need to clamp work pieces once when drilling by hand - this is much tougher going on BB plywood than MDF.
These aren't tiny enclosures - altogether approx 2 5x5ft sheets per side, and it does get a bit wearying moving them around.
like my mind, this space intentionally blank
Old 24th April 2012, 05:59 PM   #93
JRKO is offline JRKO
JRKO's Avatar
Send a message via AIM to JRKO
Originally Posted by chrisb View Post
In fact the most time consuming part so far has been fitting and drilling all those holes in the full length and lateral bracing.......
........These aren't tiny enclosures - altogether approx 2 5x5ft sheets per side, and it does get a bit wearying moving them around.
Yup - it took me 2 days with help on the first - I was exhausted. Heavy box ain't they?
If I'm not making noise, I'm making something to make noise
Old 24th April 2012, 06:17 PM   #94
thankfully the driver's aren't particularly massive themselves
(dual CSS SDX10s, anyone?)
Old 24th April 2012, 06:49 PM   #95
KyleinCowichan is offline KyleinCowichan  Canada
KyleinCowichan's Avatar
Wow, that would be a bit heavy! Casters sound like a good idea! Will there be a version of this at DIY Fest this year?
KM
Old 24th April 2012, 06:57 PM   #96
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
The goal is to have it sorted by diyFEST
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 24th April 2012, 09:02 PM   #97
KM
I was thinking something like these would make for easier moving about
Old 24th April 2012, 09:20 PM   #98
Two of those on the back, a foot on the front, and a telescoping handle to drag it around like luggage!
KM
Old 24th April 2012, 09:33 PM   #99
frugal-phile(tm)
planet10's Avatar
Those aare very nice Chris.
Given that our target is small PA work, that kind of thing is the goal if the beta gives us good feelings.
dave
Old 25th April 2012, 09:57 AM   #100
JRKO's Avatar
I like those wheels Chris! I was thinking about popping a couple of static wheels an inch or two from the base on the back with a small flip-down handle on back at the top. Just lean it backwards and voila!.....
....a matching L & R set of Emken Luggage
BTW when is diyFEST? I counting on Dave & Chris' design & build skills to wow everyone!
Ladies & Gentlemen - The EmkenHide this!Advertise here!
Can you gentlemen help me design a Zobel circuit? Broadwayautoclinic Multi-Way 5 16th June 2011 10:04 PM
Hi Ladies and Gents Steven-H Introductions 1 17th January 2007 05:18 PM
Swinik VS Quad -- where is your Bridge, gentlemen? Wavebourn Solid State 20 16th October 2006 08:10 AM
Hello ladies(?) and gents Duck-Twacy Introductions 3 16th January 2004 08:41 AM
Ladies in audio Doug Everything Else 8 2nd February 2003 11:21 AM
