Repairing a voice coil
Old 6th March 2012, 11:40 AM   #1
Nikolas Ojala is offline Nikolas Ojala  Finland
Nikolas Ojala's Avatar
Question Repairing a voice coil
I have been a happy owner of a pair of Goodmans Axiette 101 speaker drivers. Until couple days ago I noticed a bad imbalance in the sound. I measured the voice coil resistances. The left speaker still had the correct resistance of little less than 3 ohm, but the resistance of the right speaker had increased to over 300 ohm.
It seems that the voice coil has been damaged. Probably it has received too much current. I know one situation, not very long time ago, when that may have happened.
What can I do now? I really like these speakers and I'd like to try to repair the damaged one. I don't know how to disassemble the speaker, although I think it should be possible. If I manage to disassemble and wind a new voice coil, how can I put the cone back and center it?
High-order harmonics are more offensive than low.
Old 6th March 2012, 12:23 PM   #2
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
It is really few you can do. If the wire is broken, or the coil is shortcircuited (Because of melt of the wire in turns together), the coil is unusable. Only way is replace the entire coil or rewind it.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 6th March 2012, 12:38 PM   #3
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Your biggest task is going to be dismantling the speaker without damaging any of the components like the surround and spider in the process. You'll also need to take off the dustcap. If you get that far without problems, rewinding the VC and alignment and reassembly will be relatively straightforward.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 23rd September 2012, 12:18 AM   #4
I sent an email message to the designer who is still in the business. I just hope that he would answer. I am not sure if I dare to try repairing the driver without some very good help.
I think that winding thin wire is not the hard part because I have some experience doing that. But most other phases in the process are new to me.
Old 24th September 2012, 08:46 AM   #5
VaNarn is offline VaNarn  Australia
Before you dismantle the Axiette,test the flexible wires (pigtail leads) from the chassis terminals to the voice coil connections on to the cone assembly.If these are still intact then the removal of the diaphragm has to be done with great care,as the thin cone is fragile and easily creased.The corrugated paper outer surround will be your biggest headache and the only procedure that I would advise is to use acetone as a solvent and with many repeated applications as needed to ease it from the frame.
Old 25th September 2012, 08:11 PM   #6
tvrgeek is offline tvrgeek  United States
Be sure to do this outside standing upwind. Acetone is a terribly dangerous solvent. Kills brain cells and causes cancer.
Old 25th September 2012, 08:23 PM   #7
Kindhornman is offline Kindhornman  United States
Kindhornman's Avatar
TVRGeek,
Tell that to your wife or girlfriend the next time they are removing their nail polish, most of that is acetone. Not one of the real bad solvents really but highly flammable to say the least. I don't think that you will be able to just wind a voicecoil by yourself even if you can take the complete cone assembly out without damage. The adhesives need to be very high temperature rated or you will have a speaker working for a few minutes after reassembly and then poof you will be right back to where you started. Also the wire if it does melt from over powering will usually damage the former, it will be burnt also. I would just get a recone kit for it if it is available and start from new. Most coil wires uses a special coating that is baked after assembly and this baking is what adheres the coil to the former. If you could you could possibly purchase just the voicecoil and former but I would doubt that it would be available like that
Repairing a voice coilHide this!Advertise here!
Voice Coil TheReaper Subwoofers 4 27th October 2011 06:11 PM
REPAIRING an Electro voice 1144 dickl Solid State 36 17th June 2011 06:12 PM
Voice Coil Magazine JonasKarud Multi-Way 0 8th January 2010 11:29 AM
Voice Coil Burning adelphia83 Car Audio 7 13th November 2008 01:10 PM
Single Voice Coil Vs Double Voice Coil Subwoofer Workhorse Car Audio 6 12th April 2007 07:36 AM
Copyright ©1999-2017 diyAudio
