PLLXO help
PLLXO help
Old 5th March 2012, 07:06 PM   #1
Bob Brines is offline Bob Brines  United States
Bob Brines's Avatar
Default PLLXO help
OK. I'm ready to embark on a PLLXO. I ran some numbers through the spreadsheet and notice that the cap values are several orders of magnitude smaller than speaker level XO's. Questions:
1. In my ignorance, it appears that the low valued caps will have to be ceramics or styrene type bypass caps. True?
2. I have no idea what the amp Z is. I suppose that I can simply assume 100kΩ, see what happens and adjust values acordingly?
3. I intend to use a plate amp to cross the sub. I'll start with 300Hz 1st ordrfor the high-pass.
4. Using a pot for the XO resistor, what kind of frequency range can I expect for a given cap?
Thanks,
Bob
Old 5th March 2012, 07:26 PM   #2
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
PLLXO help
Bob, is this for the Topping?
The amp Z is essentially the R to ground at the input...
For hipass, i have been using this R as the shunt element of the RC filter and just using a cap in front for 1st order... adding an additional shunt R in front decreases the net input R and degrades potential performance if you want to reach for 2nd order and also requires a larger cap.
One of the advantages of PLLXO is that it uses much smaller caps then a passive XO, allowing you to get a much better cap for your budget -- no point in using anything but good poly caps in these.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 5th March 2012, 08:12 PM   #3
Bob Brines's Avatar
Yes
OK. I can do that. The Topping reads 49kΩ, and old Yami 100kΩ and my p-p tubes 87kΩ
Putting 49kΩ into the spreadsheet gives 10.8nF. Unless I don't understand the units, which of course is possible, the smallest foil and film cap is 0.01μF, or 10pF and 10^3 too big. Where would you suggest that I sourse the proper caps?
Bob
Old 5th March 2012, 08:56 PM   #4
frugal-phile(tm)
planet10's Avatar
PLLXO help
0.01 is close enuff...
Solen Electronique Inc.
You can fine tune with a shunt R across the input R.
dave
Old 5th March 2012, 09:19 PM   #5
PeteMcK is offline PeteMcK
re:'Using a pot for the XO resistor, what kind of frequency range can I expect for a given cap?' - you can use a resistor in series with the pot to set the range
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 5th March 2012, 11:22 PM   #6
Bob Brines's Avatar
Ah! So the units on the spreadsheet are really μF. I'll buy some parts for a patch box and see what happens.
Thanks,
Bob
Old 6th March 2012, 11:28 AM   #7
901Fixer is offline 901Fixer  United States
Doesn't it go:
milli = 10^-3
micro -6
nano -9
pico -12
Pico being smaller than nano that is. .01 micro = 10 nano?
Old 6th March 2012, 10:58 PM   #8
Rev. Billy Bob is offline Rev. Billy Bob  United States
Default PLLXO help
Here's on online converter that may help.
Online Conversion - Electric Capacitance
eta -When I ran 49 kohms through my first order calculator @ 300hz, my result was C1 = 1.0816326530612E-8 farads, so I think you are on the right track
Last edited by Rev. Billy Bob; 6th March 2012 at 11:05 PM. Reason: ading something
Old 7th March 2012, 02:13 AM   #9
Bob Brines's Avatar
Thanks, guys.
Bob
Old 6th April 2012, 03:55 AM   #10
pforeman is offline pforeman  United States
dave
Is this also true when using a volume pot. Or is the input impedance now the impedance of the volume pot
Paul
PLLXO helpHide this!Advertise here!
Trying to build a PLLXO andb Multi-Way 16 1st May 2017 08:44 AM
pllxo w lm3886? mrkramer Chip Amps 1 5th December 2009 12:15 PM
Anybody interested in checking my PLLXO? kirk57 Analog Line Level 6 4th December 2009 02:18 AM
PLLXO implementation lbstyling Multi-Way 14 29th September 2009 12:58 PM
Calculate PLLXO audiobomber Multi-Way 5 22nd August 2007 05:34 PM
