BK12 versus FH3 for FE126En without a corner... - Page 3 - diyAudio
Old 5th March 2012, 05:47 PM   #21
Scottmoose's Avatar
That's happened to me too...
Originally Posted by Godzilla View Post
Scott, your sim looks like it would provide some weight to the sound... Nice! I also notice you tune many of your cabinets to around 70Hz for Fostex drivers this size regardless of the physical size of the cabinet. Would you recommend a sub for these rather than stretching their bass response (and potentially spoiling their overall performance)... or do you prefer them 'as is' accepting them for what they are?
Cheers Jeff. Right, this is one of my favourite alignments for a vented box / MLTL with wideband units. Pretty much as Chris said. A sub or subs would be prefered for the LF, although I suspect a lot of small single-driver fans would be happy enough as-is, so long as their expectations are realistic.
gee - looks almost too simple, a guy could bash a pair of those out in a couple of hours
You volunteering Chris? Incidentally, OT did you get chance to try that 88 based box that shall not be named here?
Old 5th March 2012, 06:36 PM   #22
chrisb is offline chrisb  Canada
how could I say no?
see your e-mail
realistic expectations - oxymoron, innit?
... so, not as easy at it sounds, this letting go thing
Old 5th March 2012, 06:59 PM   #23
depth of vent slot?
Old 5th March 2012, 07:49 PM   #24
frugal-phile(tm)
planet10's Avatar
To late for that; http://www.diyaudio.com/forums/plane...-new-post.html
Pictures soon.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 5th March 2012, 07:52 PM   #25
I'm thinking I may end up holding on the 126 and trying the FH3, despite the current sub-optimal placement.
I think I'm more likely to win a re-arrange/reorganize the living room discussion, than I am a speaker box she doesn't like the look of.
Thanks for your advice. I have some good ideas now for the next set.
Old 5th March 2012, 07:55 PM   #26
Scottmoose's Avatar
Originally Posted by chrisb View Post
depth of vent slot?
Nominally 3/4in, but ~1/4in either way won't affect it's behaviour significantly enough to bother about.
Too late for that
No worries at this end, just didn't want to jump the gun before I got word on the last box.
Old 5th March 2012, 08:14 PM   #27
I gotta hang out in the shop tonight to spray some lacquer, so while I wait for that to dry, I'll give these a shot
OK then, the little folded VP is actually quite surprising good- not a desk topper like the Fountkenette though, and certainly not competition for the FH3/FE126
These little drivers are nicely enough made, but the design creates some downsides to actually installing them in a box
1) very small margin on cast mounting flange,
2) came with no gasket / screws
3) holes will only accept #4 or smaller screws, and they're not fully countersunk for that size
4) terminals get in the way
5) even if rebated for flush fit, any wide-band driver this size definitely needs the through hole to be chamfered
Old 5th March 2012, 08:32 PM   #28
frugal-phile(tm)
planet10's Avatar
...but the design creates some downsides...
Let me add... the awkward weight distribution had me dropping them a couple times. The protruding surround means they can't be set face down. Packaging is clunky. They do produce good bass for their size, but midrange is coloured, and top is not that extended (probably a good thing given the amps these will most often be used with)
dave
Old 5th March 2012, 08:35 PM   #29
other than that, Mrs Lincoln, how did you like the play?
extend current usage of FH3(A7.3) to include HT jjl Full Range 14 24th January 2012 08:31 PM
A subwoofer love-child of FH3 and Shadow? Brisso57 Full Range 3 8th June 2011 08:20 AM
Frugel-horn Shootout FH1+ vs FH3 Alaska Bill Full Range 6 19th April 2011 08:16 PM
FE126En in MLTL slhijb Full Range 15 21st January 2011 10:33 PM
can FH3 beat out the Onken ? Bigun Full Range 7 8th December 2010 05:52 PM
Copyright ©1999-2017 diyAudio
