#11 |
very pretty
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#12 |
Speakerholic
Yowza!
#13 |
as Cal says "Yowza!"
Of course there are always detractors of stone used for almost anything. I can only suggest that with a "batural" shaped stone as in the turntable, there is an opportunity to create stress risers, although they most certainly would not create fissures. The standing waves that could be created can have the effect of "smear" over some unknown frequency range.Granite can be notorious for this. Certainly the 100 lb. mass would minimize it. Regarding stone loudspeaker enclosures, one ought to proceed slowly and very carefully. I would suggest as a minimum that prototypes be made with painted (both sides) MDF. Get the speaker project "right", then proceed with stone enclosures. I'd also suggest Dynamat or similar on all interior faces to reduce internal reflections. And if the enclosures are not to big or the dimensions could be altered, try for a floorstander (even a somewhat short one), so that having appropriate stands would not be required). You can always fill any cavities with dry sterilized sand, glass shot or lead shot. And make sure the base plate is robust enough to support the weight. Just some thoughts. This is not that unusual, as the concrete horn loudspeaker thread demonstrates.
stew ☮ -"A sane man in an insane world appears insane." |
#14 |
That is exactly what I ran into when I built the TT. All the cutting and grinding loosened one of the seems and it just let loose. I epoxied it back together then epoxied a 1/4 plate of aluminum on the underside so it would not happen again. The result was a very dead piece as the three different layers of material dampened each other out.
My "Art" website http://home.comcast.net/~djnagle/site/ |
#15 |
This manufacturer is famous for his products: http://www.vroemen.de/steinart1/index.html
For the ambitous DIYer, scroll down a bit on this site: Scan-Speak I did a kind of a hybrid, works very well! See it here: https://picasaweb.google.com/engrave...ildingSpeakers Cheers, Martin Last edited by Tiroler; 3rd March 2012 at 09:20 PM. Reason: spelling |
#16 |
Kevin |
#17 |
Speakerholic
I've made many a stone speaker...
...wait, slight spelling difference.
#18 | |
I see the "d" on your keyboard is still intermittent, and your typing dyslexic, isn't that Dave's specialitee?
#19 |
Speakerholic
d? ok, I was thinking r.
| Please don't stone me. . . . | Nihilist | Tubes / Valves | 11 | 20th February 2010 02:44 AM |
| Cast stone as a box material | CeramicMan | Multi-Way | 0 | 23rd July 2007 09:01 AM |
| How does a stone sound? | el`Ol | Instruments and Amps | 2 | 4th February 2007 10:10 AM |
| G Randy Stone Design Help | SteveT | Solid State | 3 | 25th April 2005 07:05 PM |
| Page generated in 0.16974 seconds (100.00% PHP - 0% MySQL) with 10 queries |
