[q] drivers from an old TV
Old 28th February 2012, 02:06 AM   #1
worker is offline worker
Default [q] drivers from an old TV
I picked up 2 drivers from the old TV (phillips projection tv similar to this
http://download.p4c.philips.com/file...37_dfu_aen.pdf)
how do I determine the characteristics of the drivers -- so that then I can calculate out the enclosure for DIY build ?
is that even doable (I can post pics of the drivers)
Old 28th February 2012, 02:16 AM   #2
mikejennens is offline mikejennens  United States
This speaker DIY thing, it's pretty addicting!
mikejennens's Avatar
You'll need something along the lines of a WT-3 (Woofer Tester). Without something of the sort, there's really no way to tell what the parameters are for an appropriate enclosure. Maybe someone can help by finding a spec sheet about the speaker. Pictures of the front and back, including any printing on the magnet, might help.
Sorry I couldn't have been at least somewhat helpful.
Mike
Jolida SJ502A, Squeezebox Touch, Paul Carmody's Sunflowers, Jeff Bagby's Continuums; Planet 10 HiFi's MarkAudio A 7.3 Frugalhorns and MarkAudio CHP-70s, Nola Brio Clones with a Voxel Sub and a bunch of others...
Old 28th February 2012, 02:22 AM   #3
OK, I just found something that might be helpful. If you are a little handy, you could throw on of these together and see what you get.
Mike
Old 28th February 2012, 02:38 AM   #4
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
The Subwoofer DIY Page - Measurements
Do post pictures
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 28th February 2012, 05:50 AM   #5
GM is offline GM  United States
GM's Avatar
Look to the size of the TV as a guide, i.e. too big to bother, so OB or at least a relatively large ~aperiodic cab around 2-3 ft^3 and preferably as a TL. Note too the power supply specs is only flat from 100-10 kHz at 5% distortion, further confirming a typical TV's high Fs, Qts driver.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 3rd March 2012, 01:59 AM   #6
attached are the front and back
(took me a while to realize that the upload does not resize pics automatically, and instead I had to it)
the back has something written on it, not sure if of any importance
thanks in advance for the suggestions
Old 3rd March 2012, 12:04 PM   #7
Ron E is offline Ron E  United States
Ron E's Avatar
http://www.cartchunk.org/audiotopics...MeasureFAQ.pdf
epanorama.net/Speaker element Thiele-Small parameters
Your PC with a sound card and a tone generator software can be the signal generator/frequency counter. All you need is an amplifier and a resistor and a voltmeter. Or you can build a simple jig and use speaker workshop.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. Aldous Huxley
[q] drivers from an old TVHide this!Advertise here!
211/VT4C test data for TV-7 / TV-10 Doctorcilantro Parts 0 24th October 2008 06:41 PM
4 SALE!! avermedia tv genie vga tv tuner capture device... thing.... 4 SALE!! lone_wolf_84 Swap Meet 0 3rd February 2005 12:26 AM
Copyright ©1999-2017 diyAudio
