Alpair M6 Boat Speakers
Old 27th February 2012, 04:10 AM   #1
Waterdog is offline Waterdog  Canada
Default Alpair M6 Boat Speakers
I needed new speakers for my boat.
These use the Alpair M6 driver. Challenges on the boat are humidity and space.
I went with some tight grain fir that was laying around the workshop. Planed it to 1" thickness and constructed so that the front, back and sides can all expand and contract without splitting the cabinets apart.
A hint of walnut finished them off.
I can assure you the sound is much better than the nasty little marine speakers they are replacing!
Old 27th February 2012, 05:39 AM   #2
sayrum is offline sayrum  Germany
great idea, to take the expansion + contraction into acount. how did you build the cabinet to allow for the "movement"?
nice design!
do you hook the drivers straight to your amp or use a correction network/notchfilter... ?
greets,
daniel
Old 28th February 2012, 03:37 AM   #3
The top/bottom/sides are a rectangular frame constructed with a box joint. These will increase / decrease slightly with changes in moisture content. The front baffle and back have a small rabbet so they fit inside the frame (not too snugly) and overlay the frame at the front. These can expand and contract considerably, but will not bind with any other components. Four screws go through recessed holes in the back and hold the front on sandwiching the frame in the middle.
Plywood or MDF are much more stable materials for the purpose, but I prefer not to use these materials on the boat.
They will be connected directly to the amplifier.
Old 28th February 2012, 04:54 AM   #4
phivates is offline phivates  United States
Default stability
MDF+moisture=expansion
Alpair M6 Boat SpeakersHide this!Advertise here!
Alpair 6p vs alpair 6m vs alpair 7 timreeves Full Range 11 8th January 2013 03:37 PM
M6 lamination: what is it? jarthel Tubes / Valves 5 25th January 2012 08:36 AM
custom speakers for boat interior kford Multi-Way 1 2nd November 2010 12:47 AM
Making some tower speakers for my boat? loudsubz Multi-Way 10 22nd December 2007 11:54 PM
Wakeboard Boat Speakers lbz99smp Multi-Way 2 9th March 2006 10:32 AM
