i've just picked up 2x SOVEREIGN 12-200LT for £40 (impulse buy) from local classifieds listed as new in box. guess my fullrange driver i was looking for is kinda sorted now.
i looked on the Fane website and they have pretty good looking response to 8k then they die on their ****, so they're probably going to need a tweeter at some point. will decide after listening. until then i want to try them out on their own in the up-to 8-10k region which should be ok for acoustic type stuff? they're mentioned on a thread on here, that the person attached a phase plug to sit on the secondary cone. as far as i understand this helps with high end. any use for me before the tweeter is possibly added? what type of enclosure should i try and put these in? standard ported enclosure doesn't really fill me with excitement....
Last edited by gafhenderson; 23rd February 2012 at 02:20 PM. Reason: wrong picture |
#2 |
You could try a BiB - but it'll be massive:
A quick spreadsheet calc gives 68" tall (for Fs = 50Hz, so Fp = 25Hz), 25.5" wide, and 35.5" deep. Eep.
#3 | |
579x795x427mm which will need a pair of stands to get a 42" listening height. i measured them with hornresp (i think ) and they seem ok but not really 'spectacular', the left graph. right is the subwoofer which will likely only be on for use in movies or bass heavy music - so not that a huge amount.can i have a link to the BiB designs? i presume this is the 'bigger is better' i have seen coined a few times? i don't mind big as long as it justifies the size.
#4 |
BiB:
Terry Cain's BIB -why does it work and does anyone have those Fostex Craft Handbooks? BBBiB (with Eminence Beta 12LTA - similar in concept to yours): BBBIB Bigger Badder BIB Speaker |
#5 | |
#6 |
i'm also not going to start and complain about the amount of filth given by google when using 'bigger is better 12 inches'
#7 |
#8 |
ok BiB is pretty appealing BUT! do i really need to extend down as low as those designs go if i have a subwoofer available? especially one that is already about the size of a small woman?
#9 |
Might work well in OB, perhaps (Qts looks about right, IIRC)- 'specially with a sub to fill out the bottom end.
#10 |
| Duntech Sovereign, Totem 1 org. | ro9397 | Multi-Way | 4 | 27th July 2011 11:58 AM |
| Eminence Beta-12LTA alternative - Fane Sovereign 12-200LT | BHTX | Full Range | 7 | 16th June 2011 03:26 AM |
| VOX Sovereign schematics | vintagekiki | Solid State | 1 | 9th January 2010 12:45 AM |
| ISO Duntech Sovereign crossover | raincheck | Multi-Way | 0 | 4th December 2004 07:43 AM |
| duntech sovereign crossover | raincheck | Multi-Way | 0 | 24th July 2002 02:40 AM |
