Bass Helper Recommendations for FF85WK? - diyAudio
Old 19th February 2012, 11:00 PM   #1
goody75 is offline goody75  United States
Default Bass Helper Recommendations for FF85WK?
Not sure if this should go in multi-way or fullrange but here we go...
I am planning my first speaker build and, at the moment, I'm leaning toward using one of the Fostex WK full rangers. I think I want to use the FF85WK (for better HF dispersion) and throw in a helper woofer for bass support. I would appreciate it if anyone can make a recommendation for the woofer. I am not wedded to a particular enclosure or woofer size but I am trying to keep the width of the enclosure within reason (< 2ft). I am also working on a limited budget and would like to keep the cost of the woofers to under $60 each.
Also can anyone make a comment about whether one of the aluminum cone Dayton's (DA175, 215 or 270) might fit with the FF85WK? My guess is that they are too different but I really like the prices on them at Parts-Express.
Thanks for your help.
Old 20th February 2012, 01:53 AM   #2
chrisb is online now chrisb  Canada
excellent choice for mid/tweeter
add the following woofers to your short list:
TB W6-1139
Madisound:
SilverFlute W17 RC38
no doubt there will be other suggestions
Peerless 830657
on hiatus
Old 20th February 2012, 02:44 AM   #3
frugal-phile(tm)
planet10's Avatar
This almost falls within your criteria: EL166 MTM ML-TL (woofers are $72/pr, no white ones left thou)
They should be even better with FF85wk vrs FF85k.
We used SDX7 with FF85K in Tysen.
We are playing with a number of affordable Peerless.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 20th February 2012, 05:59 AM   #4
_henry_ is offline _henry_  Australia
2 x exodus anarchy in 1cuft3 ported.
cheers
henry
Old 20th February 2012, 03:31 PM   #5
dave
Of course, how could I have overlooked that one (other than that not available through PE or Madisound) - the above design definitely kicks
on hiatus
Old 20th February 2012, 08:41 PM   #6
Thanks for your responses.
ChrisB - The Silver Flute's have definitely caught my attention. I've browsed through the Madisound site before and saw that the SPL chart on them looks unbelievable - literally. I just now found a diyaudio thread that mentions them and includes a link to a favorable review of a high-end speaker that contains a similar (or same?) silver flute driver - with excellent base response.
FWIW, it seems from the quick search that I just did, that the people who have tried them say they have a warm sound. I've also read some similar comments about the FF85WK. So I am thinking that this might be my driver.
I should probably download a simulator - does anyone have any suggestions?
After I download the simulator, I will try to figure out an enclosure on my own but can anyone give me an idea of what kind of bass it would be capable of with a given cabinet size and porting scheme? Here are the specs but the Qts=0.29 & Vas = 28L. The link says an F3 of 60Hz in 0.42 ft3 vented enclosure but can anything better be achieved without trading off too much quality?
Thanks again for your help.
Old 20th February 2012, 09:32 PM   #7
vinylkid58's Avatar
WinISD Pro works reasonably well for vented boxes.
LinearTeam
I get an F3 of ~58Hz, so pretty close FWIW.
jeff
Old 21st February 2012, 03:29 AM   #8
dave
Sorry, Planet10. I didn't blow off your recommendation. I hastily did a search on them earlier, didn't find anything on them and didn't pursue it any further until now. The problem was that I didn't realize they were Creative Sound Solutions and I think I fat fingered the speaker name on top of it.
The price is fine. I especially like the lower Fs on these. And it is too bad there aren't any more in white because the Fs is 32.9 instead of 33.7 for the black ones . If I do go with them, I can't do the ML-TL... I didn't mention this before but these speakers will need to be more of the bookshelf sized variety, they don't have to be tiny though.
Old 21st February 2012, 04:06 AM   #9
frugal-phile(tm)
planet10's Avatar
The diff in Fs is immaterial.
These could be manipulated into a large bookshelf, fold it for a start. Changing the width would require an XO point shift. 1 woofer per side instead of 2 halves the xSection
dave
Old 21st February 2012, 04:34 PM   #10
dave
If th 36" height is maintained, could I change the OD xsection from 8" x 10.5" to roughly 16" x 6" to keep the folded depth more reasonable? With a single fold, this would put the overall cab OD in the ballpark of w16" x d12" x h18". I think that size is pretty reasonable.
Open Baffle with Aperiodic bass helper. Shoog Full Range 7 25th July 2010 12:43 PM
Fullrange + helper bass ozziozzi Full Range 18 28th July 2008 08:30 AM
Fullrange plus helper bass-suitable amps? ozziozzi Full Range 3 9th July 2006 08:24 AM
Tweeter recommendations for a helper for a fostex168ez rolfpal Full Range 0 4th February 2004 10:14 PM
Copyright 1999-2017 diyAudio
