Fostex FE126En in an Fonken enclosure?
Old 22nd February 2012, 11:08 PM   #21
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
No idea... it may work in a fonken-like box, but unlikely be optimized for any that already exist.
Do you have data measured in LEAP or LMS?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 23rd February 2012, 01:31 AM   #22
Pepe is offline Pepe  Sweden
No I donīt have any LEAP or LMS and I don know what it is eihter... hahaha.
I have little knowledge regarding speaker building I just enjoy listening to music and the flat 5īs shure do sound sweet but they arenīt givin me any tones below 150 hz in the cabs Iīm using now so they donīt match up well with my sub.
I gues Iīll try some of the closed boxes in the old coral papers, only problem is that they are HUGE, 84 liters for fo 75hz or 40 liters and fo 80 hz !!!!
if any one is interested in the old coral papers I found some scaned by diy-paradise:
coral encl plans | Flickr - Photo Sharing!
and
Coral flat10 plans | Flickr - Photo Sharing!
Thanks for the help!
Best regards
Peter
Old 4th March 2012, 05:29 PM   #23
Hi Dave.
Found this about the coral flat 5ii's
Coral Flat 5 II 14,5cm*R6,9Ohm*20Watt*SPL91dB*Fres101Hz *Qms8,9*Qes0,83*Qts0,76*Vas3,64*3,1g
I know my drivers are old, but could thees specs be used (they are the ones for new drivers)?
Does the specs change much over time and use?
Peter
Old 4th March 2012, 06:25 PM   #24
frugal-phile(tm)
planet10's Avatar
Peter,
Wow, Vas of 3.64 ft^3!!
With specs like that, you need a BIG box, it simmed nicely in an 1100 liter box (i have a sticky 1 key), an infinite baffle, or a slightly smaller aperiodic box. You'll still only get bass to about 100 Hz.
Most practical use is as a mid-tweeter in an open baffle. This would also cover for the fact that parameters will change as the driver ages.
dave
Old 4th March 2012, 10:55 PM   #25
Think the vas might be 3.64 liters, not shore though.
Wich makes vas 0.128545387 cubic feet.
Specs are from:
Vintage SpectrumAudio
Since they use metric system in Germany I assume it's in liters.
Peter
Old 4th March 2012, 11:52 PM   #26
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
Which makes vas 0.128545387 cubic feet.
I don't think that's right either. I've got 12.97 liters in my DB, but that could be wrong too. Only way to know for sure is to measure them.
jeff
Old 5th March 2012, 12:52 AM   #27
frugal-phile(tm)
planet10's Avatar
After your comment about big box, ft^3 made more sense. <4 liters is small for this size driver.
dave
Old 5th March 2012, 10:28 AM   #28
My bad, you are probably right Dave.
Don't know how I calculated that????
Should be:
3.64 ft^3 = 103.073322 liters.
Peter
Fostex FE126En in an Fonken enclosure?Hide this!Advertise here!
pair of Fostex fe126en with enable bigaudioscotto Swap Meet 2 25th April 2011 10:59 PM
WANTED pair Fostex FE126En Toppsy Swap Meet 0 16th January 2011 03:53 PM
old fostex fe126e vs new fe126en experiences?? gioz Full Range 3 14th December 2010 06:19 PM
Fostex FE126En cabinet ziocalepino Full Range 6 22nd May 2010 07:55 AM
Planet10's Fostex FE126eN... chops Full Range 59 7th February 2009 01:24 PM
