Crossover frequence and sidemounted woofer
Old 13th February 2012, 05:15 PM   #1
heinz1964 is offline heinz1964  Denmark
Default Crossover frequence and sidemounted woofer
Hi
What are the rules for the crossoverpoint in a FAST system?
What crossover frequence?
How big/small the distance between the woofer and the fullrange?
What about if the woofer is on the side of the enclosure? Is there any thing different then?
If I use a 6" side mounted woofer how high can I cross it? And if I use a 10"?
Best regards
Uwe
Old 13th February 2012, 06:32 PM   #2
I am thinking about a FAST system with the Scan Speak 10F for fullrange and a 6" or a 5" woofer on each side.
in what range should the crossover frequence be. How high can I crossover to the fullrange.
Is 300 Hz too high?
Old 13th February 2012, 07:16 PM   #3
chrisb is online now chrisb
Is 300 Hz too high?
We found that 330Hz worked just fine in a little 2-way with Fostex FF85K and single CSS SDX7 - but to a great extent it depends on the upper mid bass performance of the woofer - if it's smooth enough, you can simplify your total XO, possibly even down to a simple 1st order HP cap for the fullrange. Mind you at those frequencies, the C value can be high enough that a quality film cap can cost as much as some budget full-range drivers, and make bi-amping with passive line level XO far more appealing. (and what self-respecting DIYer doesn't have a few spare amps kicking around ? )
kinda burnt out - taking a break
Old 13th February 2012, 07:24 PM   #4
Swifty is offline Swifty  Netherlands
You should cross before the side mounted woofer goes from 4 pi radiation to 2 pi radiation, in other words, before the frequencies are high enough for the baffle to start reflecting them. so the deeper the cabinet, the lower you will need to cross. you can calculate the f3 of this point by dividing 11600 by the baffle width in cm. Example: the side the woofer is on is 35 cm wide. 11600/35 = 331.
In this example you should at least cross below 331 hz, preferably at least 100 hz below this point, depending on the order of the filter. Bear in mind that the scan speak should not be crossed much lower than 300 hz or so. So depending on the width of the woofer baffle you might need to either use a very steep filter or look at a different full range driver.
I am actually in the middle of a very similar project, using the Markaudio Alpair 7.3 and a Seas L26ROY. I am using active class D amplification with DSP filtering. This makes crossing very low a lot easier. The Alpair also alows for a lower crossover point than the scan speak.
Old 13th February 2012, 08:27 PM   #5
chris661 is offline chris661  United Kingdom
chris661's Avatar
When using such small drivers for the upper frequencies, I'd go steeper than 1st order. Even when driven by a mere 15w Tripath amp, the excursion on the smaller driver hit ~3mm p/p. This was with a 2nd order filter. In order to preserve some dynamic range, I'd make the crossover steeper, and, if possible, higher still.
I'd agree with a first order electrical crossover for the woofers, though - BSC and all that jazz.
Chris
Old 14th February 2012, 08:14 AM   #6
Default asymetric sidemounted woofer
Hi
Thanks a lot for the replys
Swifty - What if I mount the sidemounted bas asymetric, not in the middle of the side but closer to the front of the speaker? Does that change anything?
Best regards
Uwe
Old 14th February 2012, 08:29 AM   #7
Hi
Best regards
Uwe
No. The 4 pi to 2 pi transition is a result of the width of the baffle. It does not change with the position of the driver on the baffle. An assymetrical position on the baffle would help with a better ripple response in the 4 pi to 2 pi transition range but in case of the side mounted woofer the whole issue is to cross below the point where this takes place.
Old 14th February 2012, 11:21 AM   #8
Tyimo is offline Tyimo  Hungary
Where is the 11600 came from?
Tyimo
Old 14th February 2012, 12:34 PM   #9
See here
This link shows the calculations expressed in inches (4560 divided by baffle width in inches). Multiply by 2.541 to get to the number I gave: 2.541 * 4560 = 11600 (close enough anyway)
Old 14th February 2012, 05:12 PM   #10
Thanks!
Crossover frequence and sidemounted wooferHide this!Advertise here!
Would this crossover work for my sub woofer. dmrgarry Subwoofers 5 14th July 2011 12:23 AM
Woofer running without crossover jmar Multi-Way 16 30th November 2010 07:53 PM
Recommendationsfor a new woofer and crossover mlegions Multi-Way 22 4th January 2010 10:37 PM
new woofer crossover? tinitus Multi-Way 6 20th July 2009 05:55 AM
passive woofer crossover. gvr4ever Full Range 3 15th May 2009 02:02 AM
