Fullrange for open baffle - Page 2 - diyAudio
Old 23rd April 2012, 04:40 AM   #11
Garytr is offline Garytr  Canada
Originally Posted by planet10 View Post
Howbig is very big? One of th ebest OBs i've heard was with a 6 1/2" korean made alnico driver -- specifically made for OB. The baffle was 16' wide and housed both channels.
On a smaller baffle the Visaton B200 does a crediable job -- it needs phase plugs to tame the high frequencies.
dave
Dave what was the OB driver you heard, I am presently looking for one?
Gary
Old 23rd April 2012, 07:17 AM   #12
frugal-phile(tm)
planet10's Avatar
I'd have to dig it out to tell you proper... Sounds of Music? Alnico, paper cone, no dustcap. Made of unobtainium. I believe i have 1 of 2 pair in Naorth America. I suspect only a few prototypes were ever built.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 23rd April 2012, 09:46 AM   #13
zmyrna is offline zmyrna  United Kingdom
In your price range, Supravox 215 Signature Bicone is probably the best bet.
There are other nice bicone drivers, but they are not ideal for OB because of lower qts.
If you are looking strictly for a single driver OB application, you are limited to bicones and ideally a qts of around 0.7
Old 23rd April 2012, 09:48 AM   #14
Ohh, and the second choice is probably the hemp fullrangers from USA.
Search hemptone and hempcone.
Old 14th May 2012, 03:01 PM   #15
Originally Posted by Nelson Bass View Post
The Alpha 15a is not very good in an open baffle IME/IMO. Wooly sound and not very dynamic. Please consider the DeltaLite II 2515, check here: OBL11
Hi Nelson,
The Deltalite you refer to has a lower Qts than the alpha 15, with a similar Fs and Xmax. So I guess the deltalite would have a LF rolloff starting much above the alpha 15 albeit a much more rounded rolloff that might be audible as better transient bass response. Did you use a series resistor to increase the qts of the deltalite ?
How high a frequency are you playing the deltalite ? I see it rated upto 3700Hz !! And the response graph on eminence website is amazingly flat upto 3 Khz !!! So it could be technically be easily matched with just a tweeter and provide almost fullrange sound. Its response is so much smoother than even the 12 Beta LTA that is so often raved about, but sounded peaky and wooly on my flat OB.
Thanks for pointing out this driver.
Old 14th May 2012, 05:07 PM   #16
Banned
Hi Soundaatma
I heard the OBL11 in the designers workshop. See link above.
I don't believe the Alpha 15a will be much better by any modifications. Maybe slightly better but not much better. Been there done that.
Old 14th May 2012, 05:23 PM   #17
raul_77 is offline raul_77  Europe
The Betsy:
Wild Burro Audio Labs - Fullrange Speakers - The Betsy & Betsy-K Drivers
Wild Burro Audio Labs - Fullrange Speaker Projects - Basic Open Baffle Design
Regards.
Old 14th May 2012, 08:40 PM   #18
Godzilla's Avatar
Now I'm wondering about the 15" datalite in a two way econowave style speaker. How drastically does the frequency response change off axis? I'd imagine it would be drastic for a 15 inches. Can the driver be used successfully up to approx 2500 - 3500khz?
Old 14th May 2012, 09:41 PM   #19
Hi Godzilla,
I will follow your experiment with the deltalite 15 with great interest. The response graph on the Eminence site is almost unbelievable. It also drops like a rock above 3500Hz, so I guess it would not even need a lowpass filter ! For home use though, an OB may be more practical than a box cabinet.
BTW, please point me to what exactly is a econowave style speaker.
Old 14th May 2012, 11:43 PM   #20
doggy is offline doggy  Canada
doggy's Avatar
Supravox 215rtf bicone or the 64 series -8" bicone might work
Open baffle with several Philips AD4681 fullrange Calamaro Full Range 3 6th March 2011 11:14 PM
open baffle fullrange for my little nephew Calamaro Full Range 10 23rd August 2010 11:20 PM
Open Baffle Fullrange speakers chatziva Full Range 17 12th March 2010 09:55 AM
open baffle fullrange/sub or three way dvdwmth Multi-Way 3 18th June 2004 08:06 AM
Quasar Open Baffle with AER fullrange. James D. Multi-Way 7 14th April 2003 02:55 AM
Copyright 1999-2017 diyAudio
