Old 8th February 2012, 06:14 AM   #1
parak21 is offline parak21  Philippines
Default mid driver proposal
which drivers could go up to say 3khz to 4khz but can still go loud? and at the same time can give midbass punchy response as well.
these will be used for 2way configuration paired with a beyma 1' compression driver.
1. http://profesional.beyma.com/pdf/12MI100E.pdf
2. http://profesional.beyma.com/pdf/12MW%20NdE.pdf
3. http://profesional.beyma.com/ingles/pdf/12P80Fe.pdf
4. http://profesional.beyma.com/pdf/SM-212E.pdf
5. http://profesional.beyma.com/pdf/SM-112%20NE.pdf
Old 9th February 2012, 09:23 PM   #2
jimbro is offline jimbro  United States
I think you need to post this on the multi-way forum. Not sure if anyone over here is familiar with these drivers.
Old 10th February 2012, 06:42 AM   #3
chris661's Avatar
While I haven't heard any of these drivers, I'd say you can cut your list down by looking at the midrange response: some of them don't pass 2kHz.
1st one will be lightest (neo magnet structure), 2nd one will probably be loudest (high power handling), 3rd one will likely be the cheapest (reasonable power handling, ferrite magnet - nothing spectacular, but should get the job done).
Chris
Best driver for Mid Bass SETorbust Multi-Way 6 26th February 2011 05:57 PM
Mid Range driver which one the best? first_1st Multi-Way 18 22nd March 2010 03:58 PM
mid driver DIM Multi-Way 5 29th December 2005 10:26 PM
Proposal: Driver Database for ZMA and FRD Files Rarkov Everything Else 4 4th November 2003 10:22 AM
Mid driver advice (again) Duck-Twacy Multi-Way 4 29th March 2003 08:47 AM
Page generated in 0.06845 seconds (83.05% PHP - 16.95% MySQL) with 10 queries
