Old 5th February 2012, 10:07 AM   #1
Default Jensen BLH
Hi ... I have been looking at building this old Jensen corner horn. Would HornResp, ironing out the kinks, be better than trusting the engineers at Jensen to know what they were doing? The common chamber behind the vee is quite large. Most of this type (Jubilees, etc.) are made with divider. I do tend to like open as a pressure equalizer, but?
Thanks, Zene
Old 5th February 2012, 10:21 AM   #2
Scottmoose's Avatar
I think you can take it that the engineers at Jensen knew what they were doing. There wasn't a whole lot the pioneers of audio from the '30s onward didn't do. This is a fairly simple design from, if memory serves, Jensen's own Tech. Bulletin No.3 (aping Altec's famous Technical Letters).
Couple of thoughts: that box was designed for contemporary 12in to 15in drive units, be they full-range, co/triaxial or woofer. Typically, we're talking units with high efficiency and equally high Vas here, so on both counts, it needs to be big.
Old 5th February 2012, 11:06 AM   #3
Scottmoose ... Just want to make sure I spoke with straight tongue. Pic shows area I was referring to. Zene
Old 5th February 2012, 01:24 PM   #4
Scottmoose's Avatar
There looks to be a slight expansion discontinuity, which would show up on the impedance plot. I doubt it'd be a big deal though, & will help with the low-pass effect. If it really bothers you, you could put a front-rear partition in. I suspect I'd just leave it alone on the basis that life is too short.
Old 5th February 2012, 02:11 PM   #5
Scottmoose ... thx for explaination. I agree to leave alone. I've built Khorns and LaScalas and they are not easy for anyone that wants to try. Now, where is my 50 year old drawing equipment? Zene
Old 5th February 2012, 04:33 PM   #6
Bigun is offline Bigun  Canada
Bigun's Avatar
Zene,
I thought you might find this of interest too.
DECWARE CORNER HORNS
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 5th February 2012, 04:45 PM   #7
spkrman57's Avatar
If I ever get enough room to use these in some corners I have the 12" version and will find out some day how well they work. I just have hoarded too much spkr cabs over the years and it has killed my available space.
I'm hoping this spring to rectify that situation and post the results on this forum.
Regards, Ron
Tubes and horns - JBL pro for home use!
Old 5th February 2012, 05:07 PM   #8
frugal-phile(tm)
planet10's Avatar
If you search there is another thread on this horn.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
FS: Jensen JT-11P-1 line transformer WTB/WTT: Jensen JT-DB-E jsmith1 Swap Meet 0 26th August 2011 11:06 PM
Chambersize in a BLH Bkaasen Full Range 12 25th January 2011 04:57 PM
blh driver bigcatdairy Full Range 11 5th November 2008 06:11 PM
BLH or OB - ? freddi Full Range 0 30th December 2006 08:08 PM
BLH of LE8T cominup Full Range 4 24th November 2006 07:45 AM
Page generated in 0.08538 seconds (82.24% PHP - 17.76% MySQL) with 11 queries
