diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Full Range (http://www.diyaudio.com/forums/full-range/)
-   -   intentional speaker shorting? (http://www.diyaudio.com/forums/full-range/205775-intentional-speaker-shorting.html)
Etocynned 1st February 2012 10:39 PM
Was reading about this on a design pdf from here, Humble Homemade Hifi.
anyone tried this?
im tempted to try it with my B&W DM302's.
Any idea why it would make a difference or perhaps damage an amp?
Etocynned 1st February 2012 10:40 PM
To be specific he shorted the negative terminal to the driver frame by soldering.
sreten 1st February 2012 11:01 PM
Popularised by Tannoy and their 5th driver frame grounding terminal and
mentioned in : http://www.humblehomemadehifi.com/do...o-206_copy.pdf
Nothing to do with driver / speaker shorting as usually understood.
For Tannoy its just a marketing ploy, easily done inside the speaker,
and if going for an extra earthing terminal you need two, if bi-amping.
YMMV, rgds, sreten.
Juergen Knoop 1st February 2012 11:20 PM
well, since speaker baskets are usually touchable and not every amplifiers negative terminal provides ground or may be safe to touch, the whole thing isn't advisible.
nicoch58 3rd February 2012 11:41 PM
try is free....fast test, just rub a bit the varnish in the hole of one front screw (woofer?) put the wire and the screw on , connect the wire in negative of the amp....
for me work not so much but is better ,as is free is a lot better :)
planet10 4th February 2012 01:17 AM
Originally Posted by sreten (http://www.diyaudio.com/forums/showthread.php?p=2887803#post2887803)
The idea predates the Tannoy 5 terminal thing, you find a lot of vintage drivers (Philips in particular) with a solder tage on the basket.
I have a feeling that it is related to groundside electron pools.
Unless you have a typical Class D amp or any other that is a bridged balanced design, the negative terminal on the amp is not grounded.
dave
sreten 4th February 2012 01:54 PM
Originally Posted by planet10 (http://www.diyaudio.com/forums/showthread.php?p=2890914#post2890914)
dave
a) Is probably more do do with safety than anything else.
Probably a very good idea in old valve stuff to ground the
driver chassis, especially in lethal old valve televisions.
b) No comment. I'm not one for pseudotecnobabble.
c) I presume you connect the speakers extra ground
to the amplifiers casework if you are so inclined.
rgds, sreten.
planet10 4th February 2012 10:42 PM
Originally Posted by sreten (http://www.diyaudio.com/forums/showthread.php?p=2891557#post2891557)
Which requires a dedicated terminal on the speaker.
dave
Etocynned 5th February 2012 04:32 AM
The pic shows a 2" length of wire soldered from the - speaker terminal to the basket.
perhaps some second hand store electronics experimenting is in order, $20 worth of amp and speakers can be put to good use here.
nicoch58 5th February 2012 05:29 PM
Originally Posted by Etocynned (http://www.diyaudio.com/forums/showthread.php?p=2892406#post2892406)
yes but how you thinks to fix the copper on Alu basket ?
Copyright 1999-2017 diyAudio
