There were some CSS EL70 for sale in the swap meet and I went looking for possible plans or ideas. I found the the above plans and was interested in the possiblities. That being said, I have read on many occasions that the A7 in theory should best the EL70 in sound quality. What are the opinions of the possiblity of the A7 in one of these type enclosures? More info: I love the detal of the A7's, but would like more ouput/dynamics/spl and more bass. I know that a FAST is an option, but was wondering what could be had from the above type system.
#2 |
They were designed for the EL70. Other drive units will require a box designed for them.
#3 |
I understand. If the idea had merit, I was going to speak with you about the posisblity of commisioning a design for the A7's. Does the design of either of these cabinets provide the possiblity of gains in the areas I mentioned and what are some limitations and considerations?
#4 |
frugal-phile(tm)
Scott might well slap me about the head & shoulders for this suggestion, but if you had to do a flyer on a cabinet for the A7 that was not designed for the A7, i would suggest that Lotus^2 is a better bet.
It would be a fairly big flyer -- about 50". Personally i would spend my money on helper woofers. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#5 | ||
Scott and Dave might both wanna slap me a bit as well, but having a fair bit of experience building and listening to a variety of enclosures for both named drivers over the past several years, here goes: I own both drivers, and would be quite happy with either of them - actually if I had to make a Sophie's choice between the two right now, it'd probably be for the EL70. Let's hope that once current stock is depleted that some future model of Mark Audio branded paper cone driver equals or surpasses the EL70's performance. I've no doubt Mark could achieve that- market demand would be the impetus to drive production. Back to the question: there are two simple methods that could probably deliver the "more" you're looking for, with which I think you're already familiar from these fora: dual drivers per enclosure, a la the Castle Microtower, or any of several other twin systems, and some kinda FAST. When relieved of the heavy lifting, either of these drivers can work quite well in a variety of small enclosures, from simple to more complex construction details, Even when combined with helper woofers, the total size could be less than the Coniston, Lotus, etc. However, if you're still inclined to a larger / double mouth enclosure designed for the Alpair 7 that will also work with the EL70, and want to try without woofers, two words - Woden Maeshowe. Aside from the curved side panel, this is no more complicated a build than the Coniston or Lotus, and certainly squeezes the best balance of dynamics, low end extension and articulation that I've yet to hear from an unassisted single of either of these drivers. They definitely surpass the Pensil, but lack the latter's compact form factor, simplicity of build and room placement flexibility. TANSTAFL Quote:
build complexity aside, I think the primary question to be considered is - which design is most suitable to the room IINM, when Dave says "helper woofers", he's referring to what we've played with in our own FAST systems - stereo bass, XO'd in the upper 200-low300 range; active or passive your choice
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#6 | ||
Nope Quote:
I agree completely with you and Dave on the helper woofer, but it would be yet another thing to learn and my wife is starting to growl at me when I talk about audio. I have some Seas CA22RNX, but have not even looked at them other than a glance. I had considered building something like TonyGee's Classic and just stacking the a7 on top with a crossover, but once again, I dont even know if this is a stupid idea. Oh well, more reading. |
#7 | ||||
#8 |
Here is the room and a proposed FAST. For me, the difficullt thing about the B&W teardrop, is the interior cavity. What if the interior wwas kept in cube form and treated as a normal box speaker. THe main benefit of the teardrop is the baffle diffraction, correct. So if i can achieve that gain and properly addres issues with cubic interior, I have a B&W on the cheap. I would make the teardop out of quarters that could be easily shaped, finsihing the interior and cutting the face, before temporarily connecting together(pocket screws or dows) and then turned to meet the outer shape needed. As i understand it, the teardrop is excellent for diffraction, but creates problems whenusing round interior for standing waves. couldnt these be dealt with in the above proposed idea with either professional absorptionmaterial or custom made spikes like you see in anechoic chambers.
#9 |
I can get a 12" SLS right now for the same price as 10" pictured in the drawing. Pros and cons? I could always double up the 10", but seems unnecessary. Then again, I am a rookie. BTW. Te box could easily be squared off. Just playing with good looking ideas. Waves coming off driver will be below rolloff i believe, so diffraction should be a big issue, I thkn.
#10 | ||
More going on inside that teardrop than meets the eye; per "Technologies" at B&W website Quote:
Bowers & Wilkins - Sphere Tube I think it's fair to say this is a very thorough piece of acoustic and production engineering - unfortunately, price aside, there are performance aspects of the large N series that frankly leave me a bit cold. Back to your plan - you might well end up with almost perfect cube for a primary volume, in which initial reflections could be more problematic than could easily be controlled with materials that would fit inside the enclosure. A steeply tapered aperiodic or transmission line enclosure that could still be contained within your teardrop exterior might be worth considering. I hadn't clued in before to your intention to attempt this shape - out of curiosity what materials and construction methods were you planning on using?
| Coniston^2 Build | motosapien | Full Range | 40 | 24th May 2011 01:04 PM |
| Filter, super tweet for Coniston^2 | motosapien | Full Range | 31 | 1st December 2010 11:01 PM |
| Coniston: Construction Question | BL21DE3 | Full Range | 6 | 20th February 2010 06:39 PM |
| Damping Material for Coniston | BL21DE3 | Full Range | 2 | 17th February 2010 08:27 AM |
| Thirlmere Bipole using the CSS EL70 | italynstylion | CSS | 1 | 8th September 2009 07:39 AM |
| Page generated in 0.14580 seconds (86.11% PHP - 13.89% MySQL) with 11 queries |
