#31 |
#32 |
frugal-phile(tm)
Have you read the Spawn intro on the FH site? That will point you to other (explicit) BVRs? Many small horns, for that matter, a daline, are BVRs.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#33 |
frugal-phile(tm)
I see Robert beat me to one of those links...
dave
#34 | |
Regardless, you seem to understand BVR/BLH loading at its ‘fundamental’ GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#35 | |
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#36 |
frugal-phile(tm)
Note that that like (and others) have been in the Spawn section of frugal-horn.com (home of Scott's BR) for 4 years...
dave
#37 |
I guess it's a case of better late than never.
There are so many different names and so many different speaker designs that for most part I have not been able to 'see the wood for the trees'. I found the same with amplifier design, fancy names for all the different circuits - cascodes, cascades, White followers, capacitance multipliers etc. and it was quite awhile before I could see the whole picture and the connections between them all. I'm seeing that you can't categorize speakers along clear lines either, it's all a spectrum. Take the FH3, is it a horn, or is it a BVTL (big vent transmission line) or is it both and something else besides ! Actually now that I think of it, perhaps the FH3 is easier to scale since it's mostly a TL and all I need to do is keep the CSA and length the same... hmmm, a little knowledge is a dangerous thing ![]() And now that I think about what I'd like in terms of form factor (totem arro) it's not clear that it will behave as a reflex enclosure when so long and thin, it's bit between a TL and a BR. Can one add a big vent to a Pensil ?
#38 | |
GM
#39 |
well, perhaps not easy.....
#40 |
Scaling is actually easy once you understand the physics of the situation, but unless you have the math skills to work it out long hand or have a fairly unique way of looking at such things, it's not intuitive.
Trust me, I know, as scaling horn pictures using a Pantograph in my teenie-bopper years and loading them with a variety of used tabletop radio, TV, etc., drivers is how I got started and as you can imagine, I got some rather strange sounding speakers that had just about convinced me to give up on such 'flights of fantasy' as my mom called them when one day I lucked up big time! I happened to find an oval driver that sounded good enough in one of my largest scaled horn cabs [Altec 211, I learned several years later] once stuck in a corner that it became the rage within my 'circle of influence', with a number of copies made, 'hooking' me on this hobby. Of course I had no clue how to reverse engineer it, much less scale it, that was still ~ a decade away before I'd accumulated enough knowledge since I couldn't do the math in the textbooks loaned from the Ga. Tech library. Now that I know approximately what its driver specs was and that it still lives on as a staple of car audio, I've considered building another one to see how bad it really was referenced to 'FR' driver HIFI as we know it today. Since all we had available were various AM radios to drive them, I'm guessing the ~flat source BW was limited to ~ a phone's ~250-2500 Hz BW, so anything but 'full-range'. GM
| What are the pros and the cons of those 3 vas ? | tessier | Solid State | 72 | 6th December 2010 12:34 PM |
| Cons / Pros | Borat | Tubes / Valves | 34 | 1st September 2009 12:52 PM |
| 2 way + active sub in same cabinet pros and cons? | FE3T | Multi-Way | 6 | 12th September 2008 10:34 PM |
| Pros and Cons of this technique? | G | Tubes / Valves | 35 | 23rd October 2003 05:37 PM |
| what are the pros and cons of valve amps? | pkgum | Tubes / Valves | 18 | 30th November 2001 07:33 PM |
| Page generated in 0.13379 seconds (81.54% PHP - 18.46% MySQL) with 11 queries |
