On a design note
On a design note
Old 29th January 2012, 01:06 AM   #1
jjl is offline jjl  Australia
Default On a design note
I am part way through building a set of Mar-Ken73 and was wondering a couple of things re the construction.
1. The central brace has numerous holes (about 40%) of the total area. All the images I have seen show these types of braces have holes with square cut edges. Not being totally up to date with speaker design, but being a guitar maker, I wonder why these edges are not rounded over.
2. If rounding may be beneficial (or at least not detrimental - it would look better), would it also be of benefit to round the vent hole which also has square cut edges as well as the baffle that creates this vent.
3. On a different but related topic, this mainly to the administrators, I think this site would benefit from a DIY section that covers newby (myself) questions such as - what glues, why use some types of materials, what connections are best and where to place them and run internal cables/wires, how to attach baffle material, how to seal corners etc etc. The list is endless, but covers basically how to construct a cabinet from start to finish.
Jeremy
Old 29th January 2012, 01:14 AM   #2
mikejennens is offline mikejennens  United States
This speaker DIY thing, it's pretty addicting!
mikejennens's Avatar
On a design note
Originally Posted by jjl View Post
...On a different but related topic, this mainly to the administrators, I think this site would benefit from a DIY section that covers newby (myself) questions such as - what glues, why use some types of materials, what connections are best and where to place them and run internal cables/wires, how to attach baffle material, how to seal corners etc etc. The list is endless, but covers basically how to construct a cabinet from start to finish.
Jeremy
Not to take away from this forum, but the link below will take you the Parts Express forum's Speaker Building Bible. There is a ton of great info on this thread:
The Speaker Building Bible - Techtalk Speaker Building, Audio, Video, and Electronics Customer Discussion Forum From Parts-Express.com
Have fun with your build.
Mike
Jolida SJ502A, Squeezebox Touch, Paul Carmody's Sunflowers, Jeff Bagby's Continuums; Planet 10 HiFi's MarkAudio A 7.3 Frugalhorns and MarkAudio CHP-70s, Nola Brio Clones with a Voxel Sub and a bunch of others...
Old 29th January 2012, 01:56 AM   #3
Great, there goes the rest on today....
Jeremy
Old 29th January 2012, 01:58 AM   #4
On a design note
Jeremy
Oh yeah, didn't anyone warn you? This is VERY addictive!
Old 29th January 2012, 02:25 AM   #5
GM is offline GM  United States
GM's Avatar
1. Cabs that are acoustically small for its intended band-width [BW] are presumed to have a ~uniform particle density, so the square edges are acoustically transparent. Internal damping to quell any 'hollow' sound helps too.
2. A vent's mach speed determines whether or not rounding over is beneficial, so design for < 0.5% and they are strictly cosmetic unless its radius is large enough to cause the vent tuning to rise.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 30th January 2012, 08:22 PM   #6
chrisb is offline chrisb
to be honest, the main reason I radius or chamfer the edges of the holes on my internal braces is to eliminate slivers from the plywood, and as Greg notes, on external edges until you get to larger profiles it's mostly aesthetic.
Jeremy
well there is the construction forum - but I think you're just as likely to find consensus on most of your questions there as on driver / enclosure selection here.
Mike
kinda burnt out - taking a break
On a design noteHide this!Advertise here!
LM4702 reference design note 1490 - ideal 1st amplifier? Spasticteapot Solid State 8 20th February 2013 10:47 PM
Hi all, just a note to say hello kanifee Introductions 9 14th July 2008 09:17 AM
FS: Audio Note TRANS-010; Audio Note 20H 50mA choke; Black Gate Wk "power tank" Joseph0 Swap Meet 1 24th May 2006 06:17 AM
Audio Note P-2 Yurik Tubes / Valves 0 27th February 2004 12:11 AM
