"Extended Range" Driver?
Old 23rd January 2012, 02:50 AM   #1
dabbler is offline dabbler
Default "Extended Range" Driver?
Im looking an extended range driver with the following attributes:
- 3" or 4" cone
- 400hz to 15khz bandwidth
- Exceptional detail and "dynamic" presentation
- decent SPL capability
- reasonably low distortion
Any suggestions?
Old 23rd January 2012, 02:55 AM   #2
mikejennens is offline mikejennens  United States
This speaker DIY thing, it's pretty addicting!
mikejennens's Avatar
You might like these: http://meniscusaudio.com/images/FE103En.pdf. I've got a pair of FE127's, but they're NLA. This one looks like it might be close, or even better. It might need a touch of taming around 8K, but that depends on your taste. There are a few designs for this driver and similar drivers at p10 hifi | Box Library / Other
Have fun!
Mike
Jolida SJ502A, Squeezebox Touch, Paul Carmody's Sunflowers, Jeff Bagby's Continuums; Planet 10 HiFi's MarkAudio A 7.3 Frugalhorns and MarkAudio CHP-70s, Nola Brio Clones with a Voxel Sub and a bunch of others...
Old 23rd January 2012, 03:01 AM   #3
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
The new CSS VRX126 does a pretty good job of filling your needs. This is exactly the role it was designed to fill. Production seems to have ended up more extended on the top than the protos.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 23rd January 2012, 03:05 AM   #4
frugal-phile(tm)
planet10's Avatar
Originally Posted by mikje View Post
FE103En. I've got a pair of FE127's, but they're NLA. This one looks like it might be close, or even better.
If you are going that way FF125wk or maybe FF105wk (haven't seen it yet) are likely better candidates. Early FF125 work looks like there is some work to be done to clean up the rough edges, but we are at work getting these to fill the void left by the FE127 going away.
And if you are going this way, one also needs to look at the EL70 & Alpair7.3 as well.
dave
Old 23rd January 2012, 03:19 AM   #5
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Originally Posted by planet10 View Post
The new CSS VRX126
Hmmm... time to give Bob a call?
EDIT: Not on his site yet?
planet10 needs your help:
Let's help Ruth and Dave
Old 23rd January 2012, 03:27 AM   #6
frugal-phile(tm)
planet10's Avatar
He has them. Offered to send me some last week, i told him he might as well wait till the tweeters could come with.
dave
Old 23rd January 2012, 03:28 AM   #7
Speakerholic
Cal Weldon's Avatar
Any sneak previews, ie: pics?
Old 23rd January 2012, 03:48 AM   #8
The Fostex options seem like decent bang-for-buck drivers. I did have a pair of treated Fe-207's a few years ago. I liked the "fast" presentation and coherency, did not like the distortion and honkiness in the mids at higher volumes.
I googled the CSS drivers but couldnt find much. Are they available yet?
Old 23rd January 2012, 03:51 AM   #9
frugal-phile(tm)
planet10's Avatar
1st production units reached Bob last week.
http://www.diyaudio.com/forums/css/2...26x-ld25x.html
dave
Old 23rd January 2012, 10:15 AM   #10
Looks promising, hope to see some specs on these. What size are they? Sensitivity?
"Extended Range" Driver?Hide this!Advertise here!
Your next extended range driver? Scan Speak Discovery 10F/4424G00 ScottG Full Range 74 18th February 2016 07:11 PM
"Best" extended midrange driver below $200 ? youyoung21147 Full Range 48 6th May 2011 03:22 PM
Compression driver horn as "full range"? Racket Scientist Full Range 16 18th December 2010 08:44 PM
Which 2" extended range from Tang Band? nrgy Multi-Way 9 29th September 2004 07:50 PM
What to do with these OLD 10" extended range drivers? swirv Multi-Way 9 23rd July 2004 07:27 PM
