I just built my first speakers - the BK 12 kit from Madisound. These are my first speakers with exposed drivers. One of the units sits where it gets strong sunlight (live in a passive solar home) for most of the day. What effect will this have on the driver? Should I cover it when not in use? Moving it is not really an option because of the room size and shape.
Thanks, Ralph |
#2 |
The one and only
I would shield it from long exposure to direct sunlight, although glass filters
UV quite bit.
#3 |
Hello Ralph,
i think your intuition is simply right ... i would regard a cover as beneficial. Some materials used for making driver surrounds e.g. are more prone to aging under sunlight than others ... Same for cone materials and coatings. With a cover you are on the safe side. Kind Regards |
#4 |
Thanks for the comments, I think I will keep it covered when not in use - even if my wife thinks I'm a bit on the crazy side - actually she knows this is true
Ralph |
#5 |
Cover all the glass with UV blocking film. It won't significantly alter the solar heating characteristics, but it will protect the speakers (and furnishings) from fading.
| DIY UV Exposure box with UV LEDs | Nordic | Parts | 54 | 1st October 2007 09:58 PM |
| moving drivers closer together will it effect xo | busterno1 | Multi-Way | 1 | 30th March 2004 09:58 AM |
| effect of reorientating baffle and drivers? | leadbelly | Multi-Way | 15 | 1st February 2004 03:26 PM |
| What would be the effect if 2 identical drivers are ...? | Lito | Multi-Way | 1 | 13th October 2003 09:42 AM |
| Page generated in 0.08371 seconds (72.84% PHP - 27.16% MySQL) with 10 queries |
