Experiment with FF85k - diyAudio
Old 19th January 2012, 02:54 PM   #1
Jim Shearer's Avatar
Default Experiment with FF85k
This is a prototype to see if I can build a speaker with a sonic presentation similar to the RTR 280DR which I bought back in 1974 and enjoyed until we moved into a home which is too small for them. You see, the 280DR use six tweeters and four 10Ē woofers; on the front and each side are placed a woofer with tweeters above and below; the fourth woofer is downward firing, driving through slots around the base. If I had known anything about speaker design back in 1974, I might have had serious doubts about a TWT layout--it sounds like a really poor arrangement! However, it works extremely well, with response down to 20 Hz. Sounds great at a whisper or at ear-bleeding SPLs. When you think about it, with all those drivers, theyíre pretty much loafing unless you input enough power to shatter the windows in the room.
This may be a fools errand, but how about FAST configuration with multiple full range drivers? Dipping into my cesspool of audio knowledge and searching for othersí design features I can rip-off, I speculate that a modest bass unit (FAST-like covering 30 to perhaps 200 Hz) coupled with drivers on front and sides (like the old 280DR) might just give me what I want.
So here is the first test: a small, sealed box with four FF85k. I really only wanted drivers on the front and sides, BUT, I donít know how to make three drivers work together with even power distribution unless I employ a series resistor. And I donít want a driver on the back (like the four driver Micro-Tower), so there is a fourth driver on the top (a la the two driver Micro-Tower).
I happen to have four FF85k available: two in Micro-Fonkens and two in MJK passive OBs. The first picture shows the front/sides/top glue-up. The second shows the ďunfinishedĒ product: internal dimensions 7Ēx7Ēx6Ē. Filled with AcoustaStuff. Wired series/parallel for 8 ohms. Predicted F3 is 179 Hz.
I usually veneer the exterior and apply polyurethane inside and out. Since this is only a prototype, made from scraps, and built very quickly, I didnít bother with any finish (or pay attention to appearance). My sole concern is how it sounds.
I put an old sub with plate amp under it and adjusted as best I could to match the bass with the top end. Bottom line: sounds fine, as one would expect of the FF85k. Certainly can go louder than a single driver, but it just isnít the presentation Iím looking for. I suspect that itís the top driver that I donít like.
Guess the next step is to pull the top driver, add wood blocks to reduce the volume, and re-try two different ways: 1) put a resistor in place of the missing driver for balanced output from the 3 drivers; 2) just let the front driver run by itself in parallel with the side drivers in series--which should give half the acoustic power to the front and half split between the sides.
Not sure how soon I will get to that as I have other projects coming up, including building a Dynakit ST-35 tube amp.
Cheers, Jim
A day without music is like a day without food.
Old 19th January 2012, 05:23 PM   #2
von Ah is offline von Ah  United States
von Ah's Avatar
Have some fun with this thread:
Stereophonic Sound from a Single Loudspeaker
Yours looks like a fun project!
Old 19th January 2012, 06:35 PM   #3
von,
Not sure what that thread has to do with my project, but it is interesting.
You understand that I only built one channel because I don't have 8 matched drivers available. And I wouldn't want to waste time building a pair anyway; not until I have some proof of concept.
Cheers, Jim
Old 19th January 2012, 08:17 PM   #4
von Ah's Avatar
Your box just reminded me of that thread, and I thought you might be able to use something of what's been discussed there in terms of the relative outputs of all the identical drivers.
Fe107e or FF85k? type Full Range 41 12th June 2014 05:09 PM
The FF85K Sprite Jim Shearer Full Range 71 21st November 2009 02:15 PM
Mods for FF85k badman Full Range 26 28th May 2008 06:25 PM
Ff85k? Kensai Full Range 1 25th April 2007 11:22 AM
Looking for Foster FF85K NickC Swap Meet 0 16th April 2007 04:28 PM
Copyright ©1999-2017 diyAudio
